What 2004 (STi) performance parts for upgrade and 30+HP?
Old Sep 26, 2004 | 08:07 PM
evilsti7's Avatar
Car Info: 2005 WRB/Gold STi
NO uppipe, you don't need it because it doesn't have a cat like the wrx. For 2 grand, get the cobb accessport, a turboback exhuast, sti pink springs and hardened strut top. I would look into atleast a boost gauge too, so you can see if you have boost creep or overboost.
Old Sep 27, 2004 | 10:28 PM
kewldan's Avatar
From: Houston, Texas "Drive it like you stole it.." 13.034 @ 105.19 mph
Car Info: Aspen White 04 STI, Silver 03 RS (wife's car)
Speaking of boost, how much can you crank up the boost (nominal) to still be running safe on a stock sti engine? 14.5 I heard was really conservative for our cars??? yes no?
Old Sep 28, 2004 | 02:30 PM
evilsti7's Avatar
i think the average i have heard is 17.5 (peak) fuel cutoff is around 18 i think
Old Sep 28, 2004 | 02:45 PM
STi_or_EVO's Avatar
Car Info: 02 Turbo Jetta,EVO
WOW and to think my evo runs at 19 psi stock...
Old Sep 28, 2004 | 03:05 PM
Seranin's Avatar
Car Info: 2008 Red Alert Nissan Titan
Originally Posted by bezerk
TBE, stiffer springs, no up-pipe needed, and a flash.
if you're not looking to go crazy with suspension, pink springs and hardened strut tops work great. You'll definitely notice an improvement in handling, and the ride quality actually improves. $640
can't comment on the TBE or flash as I haven't gotten mine installed yet, but any decent brand name downpipe & catback and ecu upgrade (accessport, UTEC, ecutek, Xede, etc) will get you more than your HP goal. $800-$1600 depending on exhaust, $650-$1500 depending on ecu flash.
Old Sep 28, 2004 | 06:52 PM
Onizuka's Avatar
Car Info: 04 STi
I would get these if I wanted straight line power:
Headers (It makes a huge difference in top end)
Full TBE (Turbo back exhaust)
Reflash (Like an accessport)
You'll spend about 1.5 grand that way.
With the other 0.5 large, I'd go ahead and pick up an anti-lift kit and lower control arms.
-GDO
Old Sep 29, 2004 | 10:52 PM
skoobywrx's Avatar
Car Info: 05STI/05Leg
pinks, strut tops.
Cobb AP, tires gauges.....
dont mess with MBC please
TBE, not unless you have the Cobb
Old Oct 10, 2004 | 07:30 AM
SilverSurfer's Avatar
I agree with most of these posts - a good TBE and a ECU reflash of some type will easily surpass 30hp.
For suspension, I haven't seen one post mention sway bars yet. You can get good front and rear sway bars for under $400. Also, get some STi pink or Prodrive STi springs.
If you do all four of these things it might take you a little higher than $2K - maybe 2.2K or 2.3K, but your car will be a much better all-around performer than a stock STi or Evo. These are also pretty safe mods as long as you get a reflash by a company that knows what it is doing.
Old Oct 10, 2004 | 08:59 PM
Mister 2's Avatar
Originally Posted by sonicsuby
Performance: Up-pipe and ECU reflash, springs/struts. Money spent.
Interior: Uh, gauges?
uppipe for an STi?
Old Oct 10, 2004 | 10:45 PM
These threads from the Threads of Note sticky should help you out:
What is boost creep exactly? How do I fix it?:
https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/why-did-do-boost-creep-44825/
What is a turbo, and how does it work?:
https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/anyone-point-me-good-turbo-explanation-28349/
Why shouldn't I get a Cold Air Intake?:
https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/cold-air-intake-debate-36823/
Helpful diagrams:
https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/some-helpful-diagrams-65142/
What first mods should I do to my STi?
https://www.i-club.com/forums/subaru-general-30/05-sti-now-what-68278/
Old Oct 10, 2004 | 10:46 PM
Originally Posted by Mister 2
uppipe for an STi?
He thought the poster had a WRX, he hadn't specified yet.
Old Oct 10, 2004 | 10:48 PM
My 2 cents, $200 budget, 2004 STi:
Turboback+reflash, plus wastegate porting if you live at low altitude
rear sway bar
steering rack bushings
alignment on a laser rack by someone who knows custom alignments
STi pinks and strut tops
that's probably a little over budget, but so what. One mod at a time and you'll have the money.
4CEDAWD
42
Aug 1, 2004 08:54 PM
SubySal
Dec 3, 2003 08:22 PM
1Slow///M3
Sep 5, 2003 07:28 AM
aWrxer
Apr 23, 2003 10:37 PM
noWRX
15
Feb 28, 2003 09:50 AM
