RS to WRX front rotor upgrade, RS/WRX to H6 rear rotor upgrade
Old Nov 13, 2003 | 07:37 PM
SubySal's Avatar
Car Info: 2004 2.5RS pacifica blue with black Tarmacs
Question RS to WRX front rotor upgrade, RS/WRX to H6 rear rotor upgrade
Hi, ok here's my question; this site http://www.subaruwrxparts.com/per-wrx-braking.html has some brake upgrades for the RS and WRX. Now since many of you already have WRX's I don't expect you'd know if the brackets they show for the front RS brake upgrade are off a stock ReX, on the other hand I know some of you have performed the H6 rear disc conversion and I wondered if you could tell me if those brackets were an OE Suby part or aftermarket.
Old Nov 14, 2003 | 01:45 AM
Both are OE parts. The front upgrade is the bracket and rotor of a WRX, and the rears are Legacy H6 rotors and brackets.
Old Nov 14, 2003 | 05:30 AM
SubySal's Avatar
Woo-Hoo!!! That's what I wanted to hear. You rock and roll all day long, sweet Susie (Kung Pow). Hey Ban Suvs one more question then. Will the pads from a WRX fit on a RS?
Old Nov 16, 2003 | 12:25 AM
Uncle Scotty's Avatar
Check your local boneyards for the brackets, at least for the rear.
Any Legacy or OBS with 290mm x 10mm disc rears will do, and you may save yourself the $60 each for the rear brackets.
I got the front WRX calipers with pads(~1k miles on 'em), and brackets FS...I did the 4-pot fronts right after I bought the car. I did the rear H6 about a month ago, and it was a piece of cake. No Legacys in the boneyard near me for brackets, though
EDIT: Corrected mis-information.
Old Nov 17, 2003 | 12:38 PM
Bagin,DVS's Avatar
Car Info: silver 2.5 tr 2006MT wrx
you just go to the junk yard a pull of the brackets, do you need the hardware to or what, how about the front.
Old Nov 26, 2003 | 01:50 PM
SubySal's Avatar
That's a good question. Since your keeping the same calipers I wouldn't think the pads would have to be changed, but I'm not sure either. According to the site (the one in my first post) selling this conversion you can keep the same pads.
Old Dec 3, 2003 | 08:22 PM
SubySal's Avatar
Thanks Jack, that info is very helpful.
RallySportDirect
Jun 4, 2012 07:34 AM
kaiba
Nov 16, 2011 02:33 PM
B16A2NR
Dec 9, 2009 11:36 AM
nhayden
Jul 1, 2006 08:45 AM
Toledo Joe
Dec 17, 2002 03:40 PM
