Help!!! Vacuum Leak!
ok... so i pulled a CEL last night for "system too rich (bank 1)" i am almost positive it is a vacuum leak.. but i cant find it! i pulled the tmic off, no problems down there, i checked all the lines to the intake, i checked all the lines off the turbo, and i even made sure the line to my boost gauge was on tight. any other spots i should look at?
OMG!!!
ok.. so i took it for a drive, it still is happeneing... right now im gunna let it cool off. and then re do the TMIC hoses.. but after that i dont know where to go until monday when i can get my hands on a smoke tester..
how are the 02 sensors looking?
replace all your vacuum hoses good luck.
also check the hoses to the intake. Is the box closed properly?
O2 sensors dont look bad.. like normal..
the hoses on the intake i am currently checking and replacing the belted hose clamps.
i just reclosed the box.
get a can of brake cleaner, or carb cleaner,
while the car is idleing spray SPARINGLY
as in very very little amounts around all your vacuum lines
you will find the area of the leak when the car idles up !
its a great way to find the leak but b careful brake cleaner is very flamable
silver_wrx
Aug 1, 2006 03:20 PM
circaisdashiat
Sep 29, 2005 04:31 PM
