Stalling!!! (mabey a vacuum leak??)
Old Sep 20, 2005 | 10:32 PM
circaisdashiat's Avatar
Car Info: 1995 Impreza L EJ205 V6
I installed a cold air intake on my 95 Impreza L 1.8L and it works fine but when i turn the A/C on and i let the engine idol it starts making weird sucking sounds (sounds jsut like a plunger in a toilet) and the RPM's go down almost to zero and then go back up to 1000 then back down to zero repeted untill i press the gas a little but today it finally stalled i knew it would one day but today it finally stalled out on me when i was idoling with the A/C on. I think the a/c worked fine with the stock intake but im not too sure. there are some pictures attached.
I have no idea what the big hose is, and i know that small hose is to my A/C and it sucks air but i have no idea where to put it??? Someone please help!!
Attached Thumbnails Stalling!!! (mabey a vacuum leak??)-intake1.jpg   Stalling!!! (mabey a vacuum leak??)-intake2.jpg   Stalling!!! (mabey a vacuum leak??)-intake3.jpg
Old Sep 25, 2005 | 10:52 PM
no one knows whats wrong, has any clue??? this has never happend to anyone else??
Old Sep 26, 2005 | 11:05 PM
I3eXa's Avatar
Car Info: 96 Impreza L Sedan
Well, for starters I can tell you that that big hose it a vaccum line and needs to be hooked up through the intake, like it is on the stock pipe. Sounds like you need to compare the stock/new ones and figure it out, put on the stock pipe, or get another cai.
Cp
Old Sep 27, 2005 | 09:24 PM
ya i talked to a mechanic today and he said i needed to put both those pipes into the CAI.
Old Sep 28, 2005 | 05:11 PM
SubieStylez's Avatar
Car Info: 2001 WRB 2.5RS, Gold Prodrive P1's, Stromung Dual Tip, AEM SRI, Pink "i" fornt badge
did you reset your ECU?
Old Sep 28, 2005 | 06:02 PM
ya i took my battery out completly a while after i put the intake in and its still doing the same thing.
Old Sep 28, 2005 | 11:15 PM
I3eXa's Avatar
well, obviously if it worked fine in 'stock mode' then there is something you are doing wrong when you install the new intake..
Old Sep 29, 2005 | 04:31 PM
i never used the A/c when i was in "stock mode"
hloh
Jan 19, 2010 04:56 PM
wrxisthebest
Mar 31, 2008 05:11 PM
silver_wrx
Aug 1, 2006 03:20 PM
lin_tp2
Mar 3, 2005 11:39 PM
DetailAddict
Nov 23, 2004 01:18 PM
