vacuum leak?
Old Mar 2, 2005 | 01:51 AM
lin_tp2's Avatar
Car Info: 02 wrx
vacuum leak?
i knew there are many threads out there that talks about vaccuum reading on boost gauge and i have over 50 of them. But still cant seem to find my answer. I installed by boost guage 100% correct and sure of and pretty sure there is no leak. However at idle it read 600mmhg and it would slowing go back up to 500mmgh at vacuum. the kg/cm seems to read fine because I never past 1 (stock car). when the car is off it reads a little below 0. So i was wondering if there mite be a possible leak (i dont think there is one because i checked several times) or would it be a defective gauge?
thanks
Old Mar 3, 2005 | 08:14 AM
minisiu's Avatar
try to use silicone hose
or try the feel is there have any suckion at the end of the hose ( end of the hose to boost gauge with runing engine) subaru spec. at ac off and warmed engine should be around -17hg
Old Mar 3, 2005 | 08:17 AM
minisiu's Avatar
o by the way what knid of gauge are u using??
i had vdo gauge it reads -19 to -20 hg n and i switched to autometer it reads -15hg cold engine and -16 to -17 hg warmed egine.
Old Mar 3, 2005 | 01:05 PM
lin_tp2's Avatar
Car Info: 02 wrx
cool
Old Mar 3, 2005 | 01:31 PM
lin_tp2's Avatar
Car Info: 02 wrx
i have a greddy boost gauge. silicone hose eh, i'll see if i can get some its 3/16 hose btw
Old Mar 3, 2005 | 07:45 PM
Steven@Coach's Avatar
Car Info: 2011 WRX Hatchie
Did you use the T-fitting that came with the greddy gauge? When I installed my greddy gauge it moved around like that during idle. I bought a 1/4 vacum T-fitting at kragen for like 50 cents. and it helped it some. It'll still move around alittle, but not like bfore.
Old Mar 3, 2005 | 11:39 PM
lin_tp2's Avatar
Car Info: 02 wrx
i used a 1/4 T bought it pep boys, doesnt move around at all i think
hloh
Jan 19, 2010 04:56 PM
wrxisthebest
Mar 31, 2008 05:11 PM
silver_wrx
Aug 1, 2006 03:20 PM
circaisdashiat
Sep 29, 2005 04:31 PM
DetailAddict
Nov 23, 2004 01:18 PM
