Semi-Newb Question regarding Exhaust set-up
Old Mar 3, 2005 | 09:03 AM
JMeltzer4's Avatar
Car Info: bugeye
Question Semi-Newb Question regarding Exhaust set-up
Hi everyone,
So, I'm finally taking the necessary steps to mod my WRX right. Right now, the only power mod I'm running is a Perrin Up-pipe. My goal is to build my own "Stage 2" kit and hopefully keep a cat or two (or replace with hi-flo cats).
So here is what I'm thinking:
Perrin Up-Pipe (Already installed)
Helix Catted Downpipe
Cobb 3" SS Catback
ECUTek reflash
Perrin Light-weight Power pulley.
Will I be able to put a hi-flo cat between the Helix catted DP and the Cobb exhaust? Is there anything else I should do to both be and appear more "clean". I personally want a nice chunk of power without being too bad to the environment.
What do you think of this set-up?
Thanks a lot for any input!
Old Mar 3, 2005 | 12:58 PM
rtakashi's Avatar
Car Info: 2005 wrx
Originally Posted by JMeltzer4
Hi everyone,
that's a nice set up...you don't have to put a high flow cat between your downpipe & exhaust, it's already on your
helix downpipe. good luck with your set up.
Old Mar 3, 2005 | 01:01 PM
JMeltzer4's Avatar
Car Info: bugeye
How would this set up do for CA Smog? Would it pass the sniffer? I may just put all my stocker stuff back on when the time comes.
Old Mar 3, 2005 | 01:13 PM
rtakashi's Avatar
Car Info: 2005 wrx
i'm pretty sure it would pass, just as long you go with helix catted downpipe.
here in hawaii we don't have any emission test
Old Mar 3, 2005 | 01:44 PM
JMeltzer4's Avatar
Car Info: bugeye
No sniffer? Man.....lucky.
I feel like Jules in Pulp Fiction: "I'm f'n going man, that's all there is to it, I'm f'n going"
Old Mar 3, 2005 | 04:08 PM
TurnWRX's Avatar
even if u pass sniffer u may not pass visual inspection, depending on how keen the inspector's eyes are.
Old Mar 3, 2005 | 04:15 PM
JMeltzer4's Avatar
Car Info: bugeye
Are there any better options for a Stage 2 style upgrade for CA?
Old Mar 3, 2005 | 07:41 PM
Steven@Coach's Avatar
Car Info: 2011 WRX Hatchie
You'll pass the sniffer with the helix catted DP, but not the visual. Just keep your stock turboback for that day.
Old Mar 4, 2005 | 10:25 AM
rtakashi's Avatar
Car Info: 2005 wrx
don't forget to put the oem turbo heat shield back on. (you have to cut the oem one to fit) or you can buy a cusco turbo heat shield or GRUPPE-S one.
it will help with the visual check...
RussB
Dec 22, 2007 10:43 AM
VRT MBasile
Feb 7, 2006 02:22 AM
UTWRX
May 16, 2005 10:28 PM
Daremo
Aug 20, 2003 12:56 PM
millionsofsubys
Jun 27, 2003 09:49 AM
