Help!!! Vacuum Leak!
Old 03-08-2008, 11:35 AM
wrxisthebest's Avatar
ok... so i pulled a CEL last night for "system too rich (bank 1)" i am almost positive it is a vacuum leak.. but i cant find it! i pulled the tmic off, no problems down there, i checked all the lines to the intake, i checked all the lines off the turbo, and i even made sure the line to my boost gauge was on tight. any other spots i should look at?
wrxisthebest is offline
Old 03-08-2008, 12:47 PM
honestly this is the worst problem in the world
get a smoke machine or replace the hoses and then go for gaskets
sigma pi is offline
Old 03-08-2008, 12:58 PM
OMG!!!
ok.. so i took it for a drive, it still is happeneing... right now im gunna let it cool off. and then re do the TMIC hoses.. but after that i dont know where to go until monday when i can get my hands on a smoke tester..
Old 03-08-2008, 12:59 PM
the BPV gasket is brand new btw
Old 03-08-2008, 01:20 PM
03_Impreza_Al's Avatar
whats your vacuum at?
03_Impreza_Al is offline
Old 03-08-2008, 01:22 PM
when at idle??
like around 17-18 Hg
Old 03-08-2008, 01:30 PM
how are the 02 sensors looking?
replace all your vacuum hoses good luck.
also check the hoses to the intake. Is the box closed properly?
Old 03-08-2008, 01:54 PM
O2 sensors dont look bad.. like normal..
the hoses on the intake i am currently checking and replacing the belted hose clamps.
i just reclosed the box.
Old 03-31-2008, 05:11 PM
wrx'd's Avatar
Car Info: 03 WRX
get a can of brake cleaner, or carb cleaner,
while the car is idleing spray SPARINGLY
as in very very little amounts around all your vacuum lines
you will find the area of the leak when the car idles up !
its a great way to find the leak but b careful brake cleaner is very flamable
wrx'd is offline
hloh
01-19-2010 04:56 PM
silver_wrx
08-01-2006 03:20 PM
circaisdashiat
09-29-2005 04:31 PM
lin_tp2
03-03-2005 11:39 PM
DetailAddict
11-23-2004 01:18 PM
Quick Reply: Help!!! Vacuum Leak!
