fmic or turbo upgrade first?????
Old Jul 15, 2004 | 05:44 AM
kettsupp's Avatar
sup fellow subbie owners, i ordered a turboxs tbe along with the turboxs uppipe and my next mod is either a fmic or turbo upgrade and i wanted to know which one to go first? i eventually am going to do both but i don't know which to get first. either fmic then turbo upgrade or turbo upgrade then fmic. im asking this because the stock turbo seems too small to provide enough boost for a fmic
Old Jul 15, 2004 | 06:33 AM
Egan's Avatar
I would not suggest running a FMIC on the stock turbo or stock engine management. You will be disappointed and feel like you wasted your $. An upgraded turbo will run on the stock TMIC just fine.
Ideally, you should save your money and do both at the same time, but if funds don't permit, I would suggest the turbo first. Just be sure and get some form of engine management (and no, SAFC, GReddy E-manage, and Boost Controlelrs are NOT engine management!).
Old Aug 25, 2004 | 01:57 AM
kettsupp's Avatar
will do
Old Aug 25, 2004 | 06:55 PM
4080wrx's Avatar
i agree w/ Egan save your money and get both along with engine management
Old Aug 25, 2004 | 07:10 PM
Mister 2's Avatar
I see no problem getting a FMIC first. If you know where you're going in your mod path and don't mind spending a $1,000 w/ no appreciable performance gain then go ahead and get the FMIC first. I've always taken a more conservative approach in upgrading stuff. I still have the stock turbo and I've recently purchased a UTEC, STi injectors and FMIC. I intend to install and tune all of these with the stock turbo before I upgrade it.
Old Aug 26, 2004 | 10:01 AM
wssboard18's Avatar
I would get the turbo first and run it on the stock tmic if you dont have the money right away to get both. I would also get bigger injectors, fuel pump and EM to run the turbo when you install it.
Old Aug 26, 2004 | 10:47 AM
Kwilson21's Avatar
Car Info: 2003 WRX (Black)
EM, Turbo, Injectors, fuel pump... then EM again.... then IC
... in that order.
-K
PoCkEtRoCKEt74
Hawaii Classifieds
Oct 1, 2011 04:26 AM
SubySal
Dec 3, 2003 08:22 PM
1Slow///M3
Sep 5, 2003 07:28 AM
mellowwrx54
Jun 25, 2003 11:14 PM
aWrxer
Apr 23, 2003 10:37 PM
