EJ20T Storage Question
Old Aug 24, 2004 | 08:13 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
I'm going to store my car, 9 months at a time. Should I replace the engine oil or drain it out and leave it empty? And are there any other suggestions for storage, besides filling the tank with gas?
Thanks!
Old Aug 24, 2004 | 08:53 PM
mmboost's Avatar
i'd leave the oil in there (not to knowledge able about oil getting "stale"). But when you finally restart, do the trick that gets the oil into the turbo without actually spinning the turbo too much. This is the only thing that comes to mind.... unfortunately I cannot remember how its done, but I just read about it on NASIOC or ScoobyMods when looking up turbo install tips. The point being, a new turbo has no oil and you don't want to spin it w/o lube. This, I'd guess, could be a similar sitatuation.
OK, not to much help here... but its the idea and the thought that counts
jason
Old Aug 25, 2004 | 11:21 AM
When my friends buy their JDM motors, they come with used oil inside them. Maybe I should do the same. Does stationary oil do anything to the metel?
Old Aug 25, 2004 | 07:05 PM
4080wrx's Avatar
my car is currently in storage my only suggestion is to fill up the tank and make sure you use a gasonline stabilizer (purchase at any automotive store) and mix with your gas. also if you can store your vehicle on jacks that would be ideal because this will prevent flat spots on your tires. lucky for me the company the army contracted starts my car once every week or two to move it around and to get the engine moving. the only thing that scares me is what they might be doing to my car. well i guess thats why they have insurance......goodluck
Old Aug 25, 2004 | 11:53 PM
Wouldn't resting your car on jacks distort your bushings in the suspension?
Old Aug 26, 2004 | 10:34 AM
4080wrx's Avatar
not to sure....................and if it did i think its cheaper to buy bushings than to buy set of tires especially if you have 18in rims
Old Aug 26, 2004 | 12:10 PM
I'm mostly worried about the motor, does anyone else know if I should keep my engine stored with oil or without?
Old Aug 26, 2004 | 12:43 PM
Froride1's Avatar
Car Info: 2004 San Remo Red WRX
Store it with the oil in it. I have heard that changing the oil before you store it is a good idea too.
Old Aug 26, 2004 | 03:22 PM
PyroManiac's Avatar
From: Are you too one of the few still living the past? Well I can change that! With a simple wicket. Yes, my friend, a wicket. PM for details.
Car Info: No car right now....sob.
I would also hook up a trickle charger to help prolonged battery life.
DesolationSuby
Apr 13, 2006 02:59 PM
My_Red_Suby
22
Oct 26, 2004 10:24 AM
subyspecialist
May 3, 2004 09:56 AM
calicam
Mar 12, 2004 04:41 AM
XeroSygnal
Mar 21, 2003 05:56 PM
