loss of boost @ 5250?
Old Feb 5, 2005 | 02:27 PM
Please don't crosspost the tech forums. Those of us who read this forum read the other engine forums too.
Old Feb 7, 2005 | 07:26 AM
Egan's Avatar
You might want to switch back to the stock bypass valve (BOV) and see if that cures the problem. I had a lot of issues with the GFB 50/50 on my WRX. I ended up removing it altogether.
Old Feb 27, 2005 | 11:30 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
i had issues when installing a bov..........check your lines.
turned out my vaccum line wans't totally secure
Old Feb 28, 2005 | 01:09 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
also, keep in mind that if you are still running on the stock turbo/stock ecu(no reflash)....you will notice that after about 5250-5500 the turbo will "flatten out," Basically the turbo is just about maxxed out, at cant produce much more "go" at that point. A reflash will help this issue somewhat.....but the true fix for it is to upgrade the turbo then reflash the ECU.
In anycase, even if you are maxxing out the stock turbo....you wont see the boost level drop off too much.....it will just reach its maximum flow, it will drop off slightly, but then will hold thru redline.....if you are getting a sharp drop in boost levels, it could be some other issue.
-Ted
Old Mar 10, 2005 | 05:22 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
The stock ECU pulls boost down to ~9psi by redline. With a reflash you can hold ~11-13psi depending on mods as well as significantly improve top end power with timing and fuel tuning.
-- Ed
EQ Tuning
Old Mar 24, 2005 | 06:01 PM
palmerx141's Avatar
I got my XEDE and i was running a stage 1 map and was having that same problem, more or less. I tried changing my BOV back to the stock one and it didnt make any diff. I would build boost till about 14 lbs and then it would drop back to around 8 at about 5k and stay there. I sent my XEDE back to shiv and hes lookin at it for me.
Old Apr 6, 2005 | 12:19 PM
Jizzo_02SubiWRX's Avatar
Car Info: 07SubiWRX
i have the same problem. mine drops from 14-10 lbs. i think its the stock turbo an ems. just tune it an i think it'll be fixed.
Old Apr 6, 2005 | 03:42 PM
palmerx141's Avatar
well i sent my XEDE back to vishnu and they said a faulty voltage clamp was the cause for my problem because it wouldent let maps load correctly.
Old Apr 7, 2005 | 10:42 AM
GotBoost?'s Avatar
ahhhhh, good to know. Glad it wasnt anything wrong with your car, So are they gonna give you a new Xede and flash it for you?
-Ted
naptownrex
Feb 7, 2005 03:51 PM
esracer
Jun 2, 2004 02:08 PM
mmboost
Jan 9, 2004 11:25 PM
WizardnamedTim
Dec 28, 2003 01:03 PM
keith
Mar 8, 2003 10:23 AM
