Loss of Boost
Old Mar 7, 2003 | 11:45 PM
jimr's Avatar
Car Info: 2002 WRX Sedan
did you try the ECU 'quick re-learn process?'
Somewhere here on I-Club, another member posted instructions on how to 're-lteach' the ECU after it has been reset. If I remember correctly, this was 'teaching' the ECU to use full ignition advance, depending on knock sensitivity of engine (due to fuel quality, load, intake air temp, boost level......etc.)
I had the link somewhere......now iI've lost it. Maybe somebody else knows it?
Basically, it was Shiv at Vishnu explaining keeping the motor under a load at about 2500rpm under light boost (2-4psi if I remember correctly) for 5 seconds......using the dyno to regulate the load and rpm. Also can be duplicated on the street by left foot braking gently to hold engine at 2500rpm under light load/boost. I don't know all the details so don't quote me.....
naptownrex
Apr 7, 2005 10:42 AM
subawagon
Jan 18, 2005 11:10 AM
esracer
Jun 2, 2004 02:08 PM
mmboost
Jan 9, 2004 11:25 PM
WizardnamedTim
Dec 28, 2003 01:03 PM
