Strange Sound`
Old Mar 26, 2004 | 11:47 PM
sykosis's Avatar
Follow my "no rear seat passanger" policy and you'll be fine
Old Mar 29, 2004 | 01:21 PM
theworx's Avatar
Car Info: 04 Java Black Sedan
If it was a definite rubbing sound and was not the tire on the wheel well, check the sway bar. I have heard of the sway bar rubbing on the tires before during hard cornering. Check that. Does your Perrin sway bar have the stops welded to the bar? The original ones did not and caused problems with the bar "walking" and hence causing it to rub on the wheels.
Old Apr 13, 2004 | 01:55 PM
Sparrow's Avatar
Car Info: 98 Legacy
Yikes!! Rubbing at speed is not good. Tires are 225, eh? And weighted down on a hard corner may rub the fuel nozzle inlet downpipe, no? Just an idea. With good tires, the load on bushings may have added up to be enough to touch something.
Good luck on finding a solution.
lastlaugh
Dec 15, 2005 12:47 AM
crazee195
Oct 3, 2005 07:59 PM
7scooby
May 18, 2005 11:21 AM
Fantabulous
Aug 4, 2003 04:46 AM
swiftsoles
Jul 5, 2003 04:08 PM
