brake question
Old Jul 28, 2005 | 02:35 PM
mw1029h's Avatar
Car Info: 04 STi blk cloaked team blew member
Ok cool, thanks again Sir
Old Aug 6, 2005 | 12:09 AM
mw1029h's Avatar
Alright all the parts are in the house, no mistakes made, on my next day off I'm heading to easystreets to have everything installed unfortunately i'm not mechanically inclined. I'm looking for a local track event. If someone knows of one at cal spd way let me know even if its a private deal I know those cost more thanks
mw
Old Mar 8, 2006 | 02:02 PM
mw1029h's Avatar
Thumbs up
Egan, good looking out man that brake setup was really nice no brake fade or vibrations of any type ,they felt the same at the end as they did in the beginning. I now need to work on my driving, as a matter of fact I'm going to hire a professional instructor for the next event its a little pricy I heard but I think it will be worth it. I'm not trying to be a race car driver just a open track driver. 03/05/06 was the first time using your recommended setup, when should I change the fluid and or pads. thanks again Egan
Old Mar 8, 2006 | 04:25 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
mw1029h: at this point you DONT really need to change the brake fluid (like changing oil). However, using your car at the track puts the brake fluid that is INSIDE THE CALIPER under alot of stress. In otherwords, you are heat cycling the fluid alot more than you would under normal circumstances and will cause the fluid to break down faster than normal. So a good habit to practice is to bleed your brakes after a hard day of driving at the track, This will flush out all of the "Old, used" brake fluid from the caliper and replace it with fresh fluid from the Master cylinder. (MAKE SURE TO KEEP YOUR MASTER CYLINDER TOPPED OFF WITH FLUID SO YOU DONT SUCK AIR INTO THE BRAKE LINES!)
as far as your brake pads go.....just keep an eye on them and replace them before they get down to about 20% pad left.
-Ted
Old Mar 8, 2006 | 06:05 PM
mw1029h's Avatar
-Ted
OK thanks for the info Sir.
kansai_wrx
Jun 27, 2006 12:28 AM
ThisizBrian
Jun 11, 2006 08:48 PM
BlueSti389
Mar 24, 2004 07:12 AM
StopTech
Sep 3, 2003 01:32 PM
