Will the Brembo brake kit fit behind 17" wheels? (was: brake question)
Old Jun 5, 2006 | 07:59 AM
kansai_wrx's Avatar
Car Info: Impreza WRX 02'
Question brake question
Hi, I am thinking to buy a Subaru coversion brake calipers + Project Mu brake pads + brambo rotors....can they all fit on my WRX 02 with 17" wheel?
if it won't fit....what do you suggest the best big brake system for 2002 WRX? My budget it's about 1500 for the front.
Thank you..
Old Jun 5, 2006 | 08:04 PM
nokio's Avatar
Hey I'm not sure how that set up might fit but I went ahead and threw some links in to different calipers that should fit 17" rims at under $1500. Can't really comment on how good they are but atleast you can see some options.
Wilwood 6-piston
http://www.scoobytuner.com/products/...&productID=432
Wilwood 4-piston
http://www.scoobytuner.com/products/...&productID=682
Rotora 6-piston
http://www.xcceleration.com/itemdetails.cfm85.htm
Brembo 4-piston
http://www.rallysportdirect.com/shop...rs-p-2253.html
shop around cause I don't know how theses prices compare to other sites, but this is just something to get you started.
-Matt
Old Jun 6, 2006 | 05:57 AM
Wingless Wonder's Avatar
Not all 17" rims will fit over big brake kits. Confirm the clearance by contacting wheel manufacturer/distributor or by carefully measuring by making a template supplied by some brake kit manufacturers.
When I see subies (non-STi) at the track (road course), a popular mod seems to be the StopTech big brake kit. Perfectly engineered for both the street-driven and race subie.
Old Jun 6, 2006 | 12:09 PM
kansai_wrx's Avatar
Wilwood 6-piston
Wilwood 4-piston
Rotora 6-piston
Brembo 4-piston
-Matt
Thank you Matt! You links really help~
what do you have now?
Old Jun 6, 2006 | 12:10 PM
kansai_wrx's Avatar
yah, I hear stoptech is better than stock sti brake.
Thank you for your help~
Old Jun 6, 2006 | 12:32 PM
excel's Avatar
Car Info: 04 STI
most 17's will fit the kits out there for our cars, with the right offset of course
Old Jun 6, 2006 | 01:27 PM
nokio's Avatar
Hey, right now I am using a system similar to the 4-piston Wilwoods, Wilwood actually made a set that Perrin used and I have those. The reason I didn't list any stoptechs is that the cheapest I have seen them on average is around $1600+ so with your criteria in mind, I left them out. You can find a cheap set of used stoptechs that would be pretty good, I have heard only good things about them. There are also used sets of STi Brembo's which aren't that bad, definately an upgrade from the WRX set.
Used Brembo's Front + Rear -not sure if the rear brembo's directly work with the WRX
http://cgi.ebay.com/ebaymotors/2004-...spagenameZWDVW
Used Brembo's Front + Rear w/o rotors
http://cgi.ebay.com/ebaymotors/Subar...spagenameZWDVW
That's if you are willing to use Ebay
-Matt
Old Jun 14, 2006 | 10:23 PM
TheScoobyMedic's Avatar
Car Info: 05 wrx
i am a horrible person and wingless wonder has it dead on
Old Jun 25, 2006 | 05:48 PM
CreoWRX's Avatar
Car Info: '08 FSXT (Aspen White)
Originally Posted by TheScoobyMedic
to answer the original question, no, brembo's will not fit 17"
You certainly cannot make blanket statements like that. As Wingless Wonder alluded to, it depends on the wheel design (i.e. spoke design/clearance, offset, etc.). If you go on StopTech's web site, you can download a template to measure caliper clearance (for their BBKs).
Aside from that, if you have any of the wheels listed here (under the 2004 STi), they should fit with the Brembos;
http://forums.nasioc.com/forums/showthread.php?t=448097
-Mike-
Old Jun 26, 2006 | 02:04 PM
JVEC's Avatar
You have several options to choose......Brembo, Rotora, Stoptech, AP, Wilwood, Racing Brake, etc. I just went through this myself but had no limitations on wheel size. I'd stay away from both Rotora and Wilwood. From what I've heard and read on the internet, you pay over $1000 for mediocre performance at best. Wilwoods have no dust seals either. I ordered Stoptechs but they're having MASSIVE delays in production. They anticipated 4 mos. (after screwing me around quite awhile) to ship out my brake kit. So they're out. AP kits are a possibility though I've heard of installation problems. Racing Brake has pretty good reviews and you can't go wrong with Brembo.
My suggestion.......either go with an STI Brembo setup or spend a little extra jing and get the Brembo GT 328mm kit. You're already spending $1500, why not spend $400 more and get the best!
Here's mine:
http://forums.nasioc.com/forums/show...1&page=3&pp=10
Here's where I got 'em. Cheapest on the net!:
http://www.injectedperformance.com/S...=38&TopCatID=7
Good Luck!
Jeremy
Old Jun 27, 2006 | 12:28 AM
Car Info: 05 wrx
that is definately an addition to my YAY AREA vocabulary
colorado_sport
Nov 4, 2006 06:37 PM
05wrxfl
Oct 9, 2005 05:34 PM
KendallRS
Apr 23, 2005 12:42 PM
nathanellis
Dec 23, 2004 11:41 PM
Lobster Man
19
Dec 10, 2002 05:20 PM
