Brake Overhaul Question
Old Aug 17, 2007 | 08:41 PM
03_Impreza_Al's Avatar
Installing rotors pads and ss lines tomorrow. Anything I should know before I dive into this? I've never done this for so it'll be a learning experience.
Any advice would be helpful. TIA
Old Aug 17, 2007 | 09:24 PM
bizzump
Old Aug 17, 2007 | 10:39 PM
Egan's Avatar
It's pretty simple.
Your only challenge will be bleeding the brakes. Everything else just bolts right in.
I would recommend getting flare nut wrenches for the brake lines as normal wrenches tend to strip the nuts.
Good luck.
Old Aug 18, 2007 | 03:41 AM
Originally Posted by Egan
It's pretty simple.
Good luck.
Yes, I'm only nervous about bleeding the brakes.
So I would change the rotor and pads first then put in the new lines? After that bleed them?
Old Aug 18, 2007 | 06:43 AM
Egan's Avatar
You might as well do the lines last.
Make sure you take the cap off the master cylinder when you change the pads. You'll have to use a clamp to force the pistons back far enough to fit over the new pads. This will push fluid back into the master cylinder and if the cap is on you'll just build up pressure.
When you're bleeding the brakes, make sure you don't let the master cylinder run dry!
Follow the bleeding sequence correctly: FR, RL, FL, RR
Old Aug 18, 2007 | 10:22 AM
Ok bout to start in a hour wish me luck.
Old Aug 18, 2007 | 01:37 PM
anyone got tips to take off the front rotors? I even put in the 8mm bolts
Old Aug 19, 2007 | 06:13 AM
Egan's Avatar
They should pull right off once the caliper is off.
If they're stuck, it's most likely a build up of dust. You can try hitting the area around the lugs with a hammer (lightly) to break some of it up.
Old Aug 19, 2007 | 08:37 AM
Wingless Wonder's Avatar
The rotors should've popped right off after a couple of turns of those screws in the threaded holes. I have an '02 WRX and it was a cinch to remove the stock rotors.
Are you removing the rotors to have them resurfaced, or are you going to install new replacements? This may seem like a basic question but you did remove the calipers before trying to pull the rotors, right?
Old Sep 9, 2007 | 07:27 PM
Weakness's Avatar
Car Info: 2005 Subaru WRX STi
Here is HSPN's Video set for brakes...
Brake Maintenance - Part 1 (Pads)
Brake Maintenance - Part 2 (Lines)
Brake Maintenance - Part 3 (Bleed)
kansai_wrx
Jun 27, 2006 12:28 AM
ThisizBrian
Jun 11, 2006 08:48 PM
BlueSti389
Mar 24, 2004 07:12 AM
StopTech
Sep 3, 2003 01:32 PM
