Top mount or front mount
Old May 26, 2010 | 03:10 AM
ricoricanlc's Avatar
Car Info: 2005 STi
i am planning on buying an oil cooler but i am debating whether to go top mount or front mount, i have done my reserach on the pros and cons on both, but i like to heard your opinions on wich one i should get and why, bellow is a picture of the top mount i was lookin on buying, they also got the same one but with different brakets to go front mounted. what you guys think
Old May 26, 2010 | 03:27 AM
4080wrx's Avatar
i haven't had much experience with oil coolers but basic science tells me go with a front. my reasoning is because I'd imagine your oil pump will have a tougher time working against gravity versus being almost parallel to the oil pump if not lower. on top of that it only makes sense to have the core being hit straight on with air versus going through the hood scoop hitting it at an angle. i'd imagine you could probably fabricate a diverter but that would be more time and money.
just my 2 pennies
Old May 26, 2010 | 12:55 PM
Krang's Avatar
Car Info: 07 Sti
Idealy u would minimize the runs of hose between the cooler, your sandwitch adapter, and your remote filter block ( if you have one ). Front mount seems to be the way to go if you are looking for THE BEST. But the top mounted cooler looks sweet!
Old May 26, 2010 | 01:33 PM
03'EyeBug's Avatar
Car Info: WRB 03(sold) AW 03(sold) 02 Taco!
Top mount looks cool but I have a Mocal oil cooler front mounted and I can't complain.
Old May 26, 2010 | 03:37 PM
joejoe69's Avatar
Car Info: 2015 CWP STI
If you add an oil cooler, you're also increasing oil capacity at the same time. Therefore, as long as the system is filled and closed (leak free), you can run it any way you want. I know Mocal has some oil coolers with built in thermostats to decrease cold oil starts in the morning and also relieve any air pockets in the system. Make sure that if you mount it under the hood scoop, you have some kind of diverter to channel air into it instead of around it.
Old May 26, 2010 | 04:16 PM
johnboi85's Avatar
Car Info: 2005 subaru legacy gt
for an oil cooler it would depend on how is it setup. is it thermo controlled as in oil won't flow to the cooler until a certain temp has been reached or will it always be flowing? problem with the front mount setup is that it may become too cool, moreso a problem in the mainland with colder temps. in hawaii a front mount would be a good way to go but i would have a way to monitor oil temp or just go ahead and have one that is thermo controlled.
Old May 26, 2010 | 04:22 PM
Car Info: 2005 STi
it is thermo controlled, is made by hyperflow in australia.
Old May 27, 2010 | 11:44 AM
dysfunctnl doll's Avatar
Car Info: grandmas car
arent you already front mount, luis? you might change to top mount? my setup was top mount for a while...there was less lag...but youre twin scroll, so im guessing you dont have much lag anyway?
Old May 27, 2010 | 01:36 PM
Car Info: 2005 STi
hey britm were u in a rush or so, lol , u failed to read the entire thread we are talkin bout oil cooler, hahahahaha, good morning to u too :P
Old May 27, 2010 | 02:22 PM
hahah whoops! i was claybaring my car till 130 am the other day....crap, yeah...failed to read the thread, just read the title:P
bluekn8286
Aug 13, 2007 10:13 PM
Bro-Gnar
Apr 21, 2007 06:21 PM
Lazyboy
Dec 8, 2006 08:06 AM
aznsensation18
Jun 24, 2005 02:33 PM
Antonio85
Jun 24, 2005 10:24 AM
