Need Help with CEL P0302
Old 10-20-2007, 01:38 PM
4080wrx's Avatar
Location: Rockin my 6th Suby in the 808 in the past decade!
I had the CEL read and it is P0302 which is a detected misfire on cylinder #2. I have already replaced the spark plugs and tested and inspected the plug wires. I am suspecting that the main coil pack is bad but do not want to shell out $200 at this time in the event that is not the problem. My question is there anything else anyone can think of before I dive into replacing the coil pack?
Car info:
2001 Impreza 2.5RS (coupe)
Ganz Intake
axle back exhaust
4080wrx is offline
Old 10-23-2007, 02:51 PM
4080wrx's Avatar
wow no responses.......
well i ended up shelling out the 140 for a new coil pack and the car still shoots out a CEL. well back to the drawing board
4080wrx is offline
Old 10-23-2007, 06:34 PM
808subaru's Avatar
Car Info: 09 xt
Jess, what are your plugs gapped at? the wrong gapping could result in misfire i've been told.
808subaru is offline
Old 10-23-2007, 07:08 PM
chochocho's Avatar
Car Info: 91 legacy, 87 mr2, 17 forester xt
try cleaning the injectors using seafoam and use fuel injection cleaner for your gas tank
no other mods, right?
Car info:
Ganz Intake
axle back exhaust
chochocho is offline
Old 10-27-2007, 03:32 AM
4080wrx's Avatar
well check the gap on the plugs and they were within tolerance according to the service manual. unfortunately the problem still exist.....but I did learn something. it turns out the the CEL only come on when i run the air conditioner, it seems like when the ac compressor kicks on it adds an extra load and the car feels and sounds like its stumbling. i think this is where and when the miss fire happens.
now with the ac off i can still feel a subtle stumble on the engine but no CEL comes on for a miss fire.
any thoughts
Jess
4080wrx is offline
Old 11-01-2007, 02:03 AM
4080wrx's Avatar
problem solved................Thanks Shaggy!!
4080wrx is offline
Old 11-11-2007, 01:45 AM
dub81's Avatar
So what was the solution to the problem Jess?? Im curious..
thanks
walter
dub81 is offline
kyoung05
05-12-2010 01:17 PM
swackerl
12-11-2006 11:10 AM
yellow03 rex
02-25-2006 04:54 PM
smegger
01-25-2005 06:03 AM
smegger
01-24-2005 02:26 PM
Quick Reply: Need Help with CEL P0302
