Help!!!
Old Feb 1, 2003 | 02:57 AM
sub-sonic's Avatar
ed
check your ignition wire to ignition coil pack connection- most likely
its very corroded. If it is, clean the coil tower with a fine sandpaper untill you restore its brass coloring. About the wire(s)
well you have to replace it or them. The cel is flashing because of the current cyls misfires - if you correct the root of the problem it will reset itself in a few driving cycles.
_good luck
ed
neo2983
Dec 5, 2007 07:11 PM
brianrwrx03
Sep 25, 2007 09:36 AM
SONofSAM
Nov 3, 2005 09:30 PM
subaru boy
Nov 8, 2004 10:27 PM
mrruins
Dec 8, 2003 01:14 AM
