Burning oil smell....help!
Old Jun 28, 2005 | 02:20 PM
revit's Avatar
I had a similar problem
turned out to be the seal on the oil pump needed replaced
might check into that
Old Jun 28, 2005 | 07:37 PM
cudaeh's Avatar
Car Info: 2000 impreza 2.5 rs
I am not to sure where the oil pump is on these cars . I would guess that it is a crank shaft seal eather on the front or back side of the engine.
Old Jun 29, 2005 | 04:14 AM
cudaeh's Avatar
Originally Posted by WRC1
^^^Im starting to think its a rear crank seal too. I am not looking forward to that work.
~Leor
yeah thats alot of tare down. Just take your time and no matter what you do DON'T pry agenst the outter sealing surface!!!. My friend decided the best way to get his old seal out was to weasle a screwdriver between the outside sealing surface and the seal and pry it out.. by the time he was done he mangled the surface so bad that when he got the new one in it leaked out from around the seal to block seem worse than it ever did from the crank to seal.
Old Jun 29, 2005 | 07:12 PM
cudaeh's Avatar
good this you told me, i would probably do it that way to. Any uggestions on how to change it? Or even better a write up?
~Leor
The best way i ever saw to pull out a seal is to take a sheet metal screw and screw it into the seal between the crank seal and block seal . not in far enough to damnage any thing behind it but enough to get a good bite into the seal, then pull on the sheet metal screw with a set of pliers or vice grips.. as much as you may want to dont use the output shaft or block to pry agenst. I have used this to remove seals in the past and it works out well, especialy with transmission seals sence they are mostly metal.
I dont know how the engine seals are held in this will work if they are a press fit but most likley wont if they are captive.
DWNSHFT
Aug 17, 2011 04:02 PM
Tele-Viper
Jul 3, 2008 07:44 AM
WREXNFX
Sep 7, 2005 02:50 PM
gavin
Jun 28, 2005 06:52 AM
EtchyLives
Mar 14, 2004 10:36 AM
