06 Turbo Lagg
Old Sep 8, 2006 | 08:24 AM
1st Scooby's Avatar
Car Info: 2004 Impreza WRX STI
Originally Posted by WRX409
A bigger front mount intercooler will help reduce turbo lag.
I think that you will get a lil MORE lag with a HUGE front mount....
There is 5 miles of piping that needs to stay compressed from the turbo to the throttle body...hmmm hmmm
Jim
Old Sep 8, 2006 | 04:19 PM
midnitewrx02's Avatar
Car Info: 2006 CGM WRX
FMIC=more lag, the compressed air has to travel longer distance.. longer distance=more lag
Old Sep 8, 2006 | 06:29 PM
1sicwrx's Avatar
What he said^^^^
Old Sep 9, 2006 | 12:13 AM
thesenior's Avatar
Car Info: '11 STi 4dr
I find it hard to believe that air traveling at over 250mph is gonna find a few feet of piping all that troubling.
I would venture a guess that maybe some better, cleaner grounds might help the Electronic Throttle respond better and faster. Just a thought though. No idea.
Old Sep 9, 2006 | 12:12 PM
pwn's Avatar
pwn
Car Info: 09 STi, 10 Cayman S
More piping is more piping, lag is lag. By the way I went stage 1 yesterday and I definately noticed less lag and much better throttle response. Can't wait for stage 2...if I could only find a place with a f*ckin downpipe in stock.
Old Sep 9, 2006 | 12:27 PM
VRT Gump's Avatar
Originally Posted by DTO808
sup bro u change out ur intercooler?
I changed out the tiny 06 WRX TR intercooler with an STi intercooler. It helped when I put on the downpipe and ran stage 2. I cant wait until the Helix V3 uppipe finally arrives so I can add that and get a tune.
Old Sep 9, 2006 | 12:32 PM
pwn's Avatar
pwn
Did the sti i/c really help that much on stock turbo? And yea all the new helix stuff is coming to gruppe-s in mid-late october huh
Old Sep 9, 2006 | 12:54 PM
VRT Gump's Avatar
It is a little smoother and boosts a little higher with the STi intercooler installed. Not a huge difference, but slightly noticable.
Old Sep 9, 2006 | 12:56 PM
pwn's Avatar
pwn
Not to mention the new bling under the hood
Old Sep 10, 2006 | 10:36 PM
meilers's Avatar
It actually isn't distance, it is volume. All the piping has to be filled to the correct PSI to begin forcing air into the turbo, and the more air there is, the more air there is to pressurize. That being said, the lag a FMIC causes has more to do with the turbo and tune than it does with the volume; if the turbo takes a long time to spin up, it will take even longer, but a fast-starting turbo won't see as much of a penalty. The stock turbo does spool pretty quickly.
Turbo lag is most often solved by just training the driver, not modding the car. A turbo engine doesn't make power below 2500 RPM, period; you just have to train yourself to keep on the gas and shift later than you normally would with a N/A engine.
Upgrading the intercooler is a great idea, even on the stock turbo. I believed for a long time that a larger TMIC would be a waste of money, but now that I have one I am amazed at how badly heatsoak and the small TMIC was limiting the performance of the car. With the stock TMIC I noticed that the car was much faster and more powerful the first ten minutes I drove it (especially after it sat overnight in the cold) and how poorly it would perform if I drove it while the engine was thoroughly heated (say, after a 30-minute drive) or it had sat in the Arizona sun for a while. Heatsoak was costing me at least 20-30 hp, totally negating the effect of the intercooler. Turbo magazine did a test recently where the stock STI intercooler was measured at the inlet and outlet tanks while they did dyno runs. By the third dyno run, the air was entering and exiting the TMIC at 245 degrees, NO lowering of temperature at all. This was with three huge fans blowing on the car, simulating highway speed!
Old Sep 11, 2006 | 10:48 AM
dubwrx's Avatar
Car Info: 2004 STi
if you dont want lag, get a car with a supercharger... my STi has full boost at 2800-3100 rpms. how much sooner do you want it?
somewhere online always has in stock...
JDMGC8
May 29, 2009 08:07 PM
fuzzycuffs
Feb 8, 2004 06:38 AM
singsing
May 24, 2003 03:19 AM
KurleeDaddeeWRX
Mar 4, 2003 06:44 PM
samurai
Jan 16, 2003 05:46 PM
