06 Turbo Lagg
Old Aug 25, 2006 | 12:19 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
06 Turbo Lagg
is it just my car or does everyone else have it? on first gear when ur running the slowest u floor it but it doesnt respond as fast. JUST WANT TO MAKE SURE ITS NOT ME.
Old Aug 25, 2006 | 08:11 PM
lburrrna's Avatar
thats due to the electronic throttle, so it not necessary a turbo lag. NO more "drive by wire" throttle for the 06 wrx/sti
Old Aug 25, 2006 | 08:17 PM
wagonator29's Avatar
Car Info: 06 wrx wagon
for me on each gear, when im on low rpm..it doesnt respond so im guessing all 06 wrx has that lag
Old Aug 25, 2006 | 10:02 PM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
I thought that all of the new wrx and sti's are drive by wire and no more throttle cable.
Old Aug 26, 2006 | 06:49 PM
herrjr's Avatar
Car Info: AWD & RWD JDM
You're right; drive-by-wire=electronically-controlled throttle.
Old Aug 28, 2006 | 06:11 PM
damn thats retarded hahaha
Old Aug 28, 2006 | 11:18 PM
pwn's Avatar
pwn
Car Info: 09 STi, 10 Cayman S
Aren't there ways to lessen that delay though?
Old Aug 28, 2006 | 11:38 PM
VRT MBasile's Avatar
most likely can be altered with tuning. I think they build in that sort of buffer zone for smoothing cruising. With that buffer zone you'll be able to cruise at a constant speed with less speeding up and slowing down due to slight throttle movement....know what I mean? Thats just one of the things youre gonna get by going from gas pedal manually opening the throttle to it being done electronically too...
Old Aug 29, 2006 | 07:51 PM
pwn's Avatar
pwn
Yea cus I don't know where I heard this but I think the delay is actualy a value that can be changed...I think.
Old Aug 29, 2006 | 08:49 PM
true. although I'm sure there is some, although less than with the ej20's, turbo lag too
Old Aug 29, 2006 | 09:33 PM
STi489's Avatar
Car Info: 04 STi
its just the regular wrx ...the STi has no lag...maybe its the diff turbos
Old Aug 30, 2006 | 07:44 AM
VRT Gump's Avatar
It lags until about 2500-3000 then the turbo kicks in. Its a mix of the electronic control and also turbo lag in general. Plus the tiny intercooler does not help the 06 out at all.
Old Aug 30, 2006 | 01:50 PM
WRX409's Avatar
Car Info: 04 WRX
A bigger front mount intercooler will help reduce turbo lag.
Old Aug 30, 2006 | 04:09 PM
pwn's Avatar
pwn
A bigger top mount would further reduce it
Old Sep 2, 2006 | 04:36 AM
DTO808's Avatar
Car Info: 06 WRX TR
sup bro u change out ur intercooler?
