top mount intercooler question!?
Old Nov 11, 2004 | 06:55 PM
NJ Dino's Avatar
Car Info: ATR Catback, HKS Downpipe, Injen CAI, 17x7.5 Rota Subzeros/Falken Azenis, Tein HA's, Apexi-SAFC,
quick question, my setup is intake turbo back uppipe headers avcr and safc. running 1.15 bar stock turbo and stock topmount. when I put the TSX top mount the boost dropped signifigantly. I couldnt tell if the car was running slower though. what shoudl i expect? if the pressure dropps 3-4psi should the EBC compensate and still run the full target boost?
Old Nov 13, 2004 | 10:49 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
It is normal for boost to drop with a larger intercooler. When I upgraded to an STI tmic, My boost dropped about .15 bar.
Old Nov 13, 2004 | 03:05 PM
NJ Dino's Avatar
since your boost dropped though, did you car get slower?I understand that the intercooler creates a pressure drop but does the car run faster because its runs cooler with a bigger intercooler or does it in fact run slower with a bigger intercooler and boost drop. What I dont understand is since there is a pressure drop of about 3-4 psi depending on what gear and rpm I am at, should my AVCR correct it? the boost controler is set at 1.15bar and doest ever hit target boost right now? any info would be great. thanks
johndabrit
Apr 17, 2010 01:41 PM
Lazyboy
Dec 8, 2006 08:06 AM
Khooda
33
Oct 27, 2006 11:02 PM
aznsensation18
Jun 24, 2005 02:33 PM
Antonio85
Jun 24, 2005 10:24 AM
