Stock EGT Removal Question
Old Mar 14, 2004 | 03:09 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
Question Stock EGT Removal Question
I removed my stock EGT sensor in the up-pipe and used a resistor fix. Would my exhaust gas temperature be too high and not be able to detect it?
Old Mar 14, 2004 | 04:09 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Yes. This isn't a good idea to do if you still have the stock uppipe with the cat in it. If your EGT probe went bad and you've got the stock pipe, get a new one and install it. The resistor mod is only recommended when a catless uppipe is installed and the probe is no longer needed.
Old Mar 14, 2004 | 04:14 PM
i have a catless up-pipe. so the egt is there only to check if the pre-cat is on fire? are there any other reasons why the egt would be there?
Old Mar 14, 2004 | 04:34 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
Nope. You did the right thing.
Old Mar 15, 2004 | 01:15 PM
BajanMonkey's Avatar
Car Info: Silver 04 WRX
When you use the resistor fix, are there any disadvantages/problems with just leaving the disconnected stock EGT sensor in a catless uppipe?
Old Mar 15, 2004 | 01:42 PM
There is some rumor-like concern that the sensor *could* break up and totally snarf up your turbo. That being said I've never read a post where it has happened.
Personally...I just went on the safe side and plugged the hole. M12x1.25 bolt (as short as you can find) and some high-temp threadlocker will do nicely.
Old Mar 15, 2004 | 01:46 PM
Thanks much!!
Old Mar 15, 2004 | 07:14 PM
oops, i didnt use any hightemp threadlock. but instead, i used a crush washer. is that ok?
Old Mar 16, 2004 | 12:05 AM
AzN121184's Avatar
Car Info: civic
sometimes, people worry too much.
Old Mar 16, 2004 | 03:28 AM
ScoobyBoy's Avatar
you should be fine ryan. you shouldnt have any worries with or without thread lock or a crush washer.
Old Mar 16, 2004 | 07:39 AM
thanks guys!
JASC
Nov 27, 2012 02:42 PM
DetailAddict
May 3, 2007 03:08 PM
Subasaurus
May 25, 2003 05:00 PM
spdkills
Jan 25, 2003 03:48 PM
Zeke21
Jan 2, 2003 05:23 PM
