has anybody attempted the egt sensor removal from their aftermarket up pipe?
Old Jul 17, 2012 | 06:07 AM
JASC's Avatar
Car Info: 2003 WRX
To make a long story short, going in for a tune next week, tuner told me to remove the egt sensor from the up pipe.
Now im at a stand still trying to get this sucker out. I used half a bottle of liquid wrench and still it wont budge without rounding off the edges of the bolt.
A plan of attack i have thought of is using a dremel to get the thin metal insulation that the wire is covered by out of my way to get a 6 point wrench in there, or even a gator grip socket.
Does anybody else have ideas?
Old Jul 17, 2012 | 07:33 AM
SUMBARU's Avatar
Car Info: 05 LGT Wagon, 06 LGT Wagon
I had same problem before. That EGT sensor body is very thin, might not come out unless you bring it to a exhaust shop to heat it up with blow torch. Good luck! I ended up buying a new UP.
Old Jul 17, 2012 | 07:51 AM
JASC's Avatar
Car Info: 2003 WRX
I also was thinking of removing the DP and using a thin cheater bar. That sensor is just in a funky spot.
Old Jul 17, 2012 | 09:08 AM
Jimboi's Avatar
Car Info: 2005 sti
Sensor removal socket? Try that one?
Old Jul 18, 2012 | 12:21 AM
JASC's Avatar
Car Info: 2003 WRX
i dont think that would help out as much, since its so tight down there. Im more resorting to removing the DP...
Old Sep 8, 2012 | 01:58 AM
Nyctercel's Avatar
Car Info: 2002 wrx
I just removed it today! Boy its a killer! Size 14mm 6point open socket The craftsman set!!! I cut the metal stem sticking out and slip the socket in use a pry bar against the turbo and ratchet and got it to spin just enough to use my hands!!!
Old Oct 3, 2012 | 02:08 AM
JASC's Avatar
Car Info: 2003 WRX
I cheated and took it to my buddies shop its much easier to access the up pipe when the car is in the air. Im sure if you threw an exhaust shop 20 bucks theyd let you use their lift for half an hour
Old Nov 27, 2012 | 02:42 PM
apexwagon's Avatar
Car Info: Sti hatch
may want to do this resistor install too, if ou later need to smog the code wont come up..
P0546 - Exhaust Gas Temperature Sensor Circuit Malfunction (High Input) - Common Check Engine Light (CEL) Codes
A.V.E.
Apr 14, 2011 07:49 PM
stets
Hawaii Classifieds
17
Jan 17, 2011 07:24 PM
lazybummm
Apr 24, 2006 12:02 AM
spdkills
Jan 25, 2003 03:48 PM
