2002 wrx
Old Nov 27, 2012 | 08:17 PM
02wrxguy's Avatar
2002 wrx
So my car which is a 2002 wrx with the ej20 motor has recently started misfiring , it idles at like 1300 rpm and is misfiring on cylinder 1 and 3 giving off codes only p0301 and p0303 on the obd2 scanner. Anyone have this problem or think they know the cause? I'm leaning towards a bad fuel rail because both cylinders are fed fuel off the same rail , does that seem like a cause? Still gunna pull the plugs and check em eventhough they have less than a thousand miles on em . Please respond with any info , I miss driving my subie life ain't the same driving auto now : /
Old Nov 29, 2012 | 02:51 PM
MEDIKATEDWRX's Avatar
Check all ur vacuum lines ...first and replace ur plugs
Old Nov 29, 2012 | 02:55 PM
tourexy's Avatar
Car Info: 02 PSM Impreza WRX
If not check your coilpack also
Old Dec 6, 2012 | 12:45 AM
kindaflush's Avatar
Car Info: 2002 impreza project
ya id suggest checking coil packs and your plugs... easiest way to see if you have a bad coil pack is taking off one of the good ones (cylinder 2,4) and switching them with the other ones... also do you have any mods? like possibly a lightened flywheel? because that could cause a misfire code as well. either way good luck man!
zulatron
Feb 25, 2015 12:01 PM
ZombieFetuz
Wanted
May 14, 2012 02:02 PM
impreza69
Feb 5, 2006 11:26 AM
UM-WRXer
May 7, 2004 07:53 PM
