Changed my spark plugs, noticed something interesting.
Old Nov 6, 2004 | 06:34 PM
jigga's Avatar
Car Info: 02 wrx
looks to me like you were running lean at some point in time.. from the grey colour of the electrodes. Were these the original plugs on the car?
the aem intakes are notorious for making the wrx run lean, and dangerously lean in some cases, which might explain the condition of the plugs
Old Nov 6, 2004 | 08:13 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
They look ok. Plugs take a beating with the turbo. I looked at mine today (48k miles) and they look just like that, and my engine is and has always been all stock. I was going to install iridiums and I freaking broke one because the rubber thing is missing from my socket. WHat a pita.
Old Nov 6, 2004 | 09:17 PM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
Are you guys changing your plugs by yourself? I would like to but I am not sure how easy or hard it is to do. I know they are not right there for you to get at so what is the procedure? Anyone have a link with pics?
Old Nov 6, 2004 | 09:41 PM
MO REX's Avatar
Car Info: 02 PSM WRX
It is a little time consumeing the first time but with the right tools its not too bad. Here is the thread that I used my first time http://www.scoobymods.com/forums/showthread.php?t=3017.
Good luck
Old Nov 6, 2004 | 09:46 PM
MO REX's Avatar
Originally Posted by Dm0n3y002
So i got around to changing my spark plugs today, they had about 50,000 miles on them and i noticed that on the battom on the little prong thing "dont know the technical name" alittle bit of the metal seems to be eatin away. The car is bone stock now, when i got it, it had an aem cai and catback which i took off once i got the car and replaced with all stock goodies. Is this something i should worry about?
If the pics dont show up let me know.
http://f2.pg.briefcase.yahoo.com/dm0n3y002
Here is a link to a search that shows you how to read your spark plugs http://search.yahoo.com/search?p=rea...b-t&fl=0&x=wrt.
Old Nov 7, 2004 | 04:12 PM
HellaDumb's Avatar
Yes they are the origional plugs. Your car is stock and the plugs look the same? Is the battom un-even like mine, like some of the metal has melted away alittle?
Well, from what I can see from the photo (can't zoom in), mine look about the same. The reason for the platinum is because it isn't supposed to eat away like the other metal parts.
Either way, I'd just change them and check 'em out in another 15k-30K miles and see how they look.
Old Nov 7, 2004 | 10:33 PM
XkrazyAsianX's Avatar
Car Info: SGM 135i
swt, thx for the links morex... and also at what milage do you propse i change my sparkplugs, i have helix up and downpipe, borla hush catback, and perrin crank pulley. just thought i'd ask thx for the reply.
Old Nov 8, 2004 | 08:47 PM
MO REX's Avatar
I think the manual tells you to change them every 30k but my car has an upipe, full TBE and a stage 2 reflash and I use the coppers instead of the platinum's so I change them every spring.
Old Nov 10, 2004 | 08:23 PM
MO REX's Avatar
manual says 60k
I just looked at my manual and you are correct. I didnt read the manual close enough and I was looking at cars that dont have a 3.0L or turbo.
Thanks for the clarification.
Bagin,DVS
Mar 25, 2008 10:22 AM
Wrx2fast4ufool
Mar 10, 2006 11:15 AM
DetailAddict
Oct 21, 2005 03:11 PM
six1five
Feb 7, 2004 09:31 PM
scsi
Jul 20, 2003 06:39 AM
