boost leak?
Old Apr 5, 2005 | 07:46 PM
DLN84's Avatar
Car Info: 2002 Subaru WRX sedan
boost leak?
so, just got home from gruppe-s...tried to tune, but my car wont boost over 14 psi. so far mods are:
vf34
sti injectors
walbro
gruppe-s headers
perrin turbo inlet
turbo xs fmic and intake
and other basics
I have a feeling that it might be the bypass valve that came with the fmic kit. Does anyone know good of quality that is? Anyone have a way to "more easily" find leaks? When I get to higher RPM and higher boost, it kinda sounds like a whistle as if the bypass valve is leaking so i dont know what to do. I already have all 6 washers in there. Thanks
Old Apr 6, 2005 | 01:56 AM
is it a turbo XS BOV?
is the bov cracked open at all ? did you clean it before putting it in?
Old Apr 6, 2005 | 04:08 AM
DLN84's Avatar
bov
i think that may be the problem. I may have to clean it. How do i do that? it is the bypass valve included with the turbo xs fmic kit.
Old Apr 6, 2005 | 12:24 PM
take it off dissassemble it and spray with WD 40 and lube it up a little bit
Old Apr 6, 2005 | 12:33 PM
DLN84's Avatar
bov
what kinda lube would you say?
Old Apr 6, 2005 | 11:12 PM
what ever kind of oil you have laying around
maybe motor oil im not 100% sure call them up and ask they might tell you something specific.
i mean a few drops should do the trick
Old Apr 8, 2005 | 11:34 PM
DLN84's Avatar
bov
i dont konw i called turbo xs and the guy seemed to refuse that there could have been something wrong with the bypass valve. I told him a few others have had the same problem i have, and he insisted that it was due to install error. and he said hes sure it isnt the bypass valve and it is that the pipes must not have been installed right. so that wasnt much help, but he said def dont lube up the bypass valve.
Old Apr 12, 2005 | 10:30 PM
DLN84's Avatar
bov
anyone else know? im prob gonna check the couplers, clamps and piping connections too.
vayrogar
Mar 16, 2012 07:45 PM
snaggleto0th
Sep 12, 2010 09:54 PM
brucelee
Aug 2, 2010 09:39 PM
ScoobyRoo20
Sep 9, 2003 04:43 PM
bigdaddy
Jul 10, 2003 12:09 PM
