bigger intercooler
bigger intercooler
My friend and I were bored on Saturday and decided to put his aftermarket intercooler on my 05 wrx. This must be 2 or 3 times bigger than the stock intercooler. I don't notice a difference. Are there any negative effects (or positive) that I should be concerned about? Thanks
From what I understand you will only benefit from a aftermarket
intercooler.I know your engine temps will go down and allow you
to make more power.Most people have told me that a intercooler
upgrade isn't necssary unless you have a turbo upgrade but, you
will still benefit from it even with the stock turbo.
Im sure subaru put a good sufficiant intercooler on as is, so unless your ready to make serious power i dont see why its necessary. But its cool to mess around if you have the chance.
If you are thinking about a bigger intercooler on the stock turbo, you should have a catless exhaust and custom tune.
A bigger IC on the stock turbo (WITH tune and exhuast!) will be an awesome street setup! It will spool faster and boost harder when tuned right.
I have this setup and its great. 16-18lbs of boost comes on quick and holds through out most of the rev range
This was with 55K miles, up, TBE w/high flow cat, silicone IC hoses, TurboXS TMIC and custom ecutek by Mike @ gruppe-s on 91 octane. I believe this is about 10-15 hp/tq short of a stock sti
[/QUOTE]
[/QUOTE]
Originally Posted by ipozestu
How long were you on it for in this pic? EGT's look kind of low. You might be able to lean out some of those ponies for bigger gains.
You're right about leaving some hp on the table...my car wasnt running so great when I brought it in to get tuned. Mike didnt want to do any thing "too crazy" so he left me with a more conservative tune. It still kicks butt though! EGT's get the hottest ~ 1600, after flooring it on the freeway during top speed runs.
I want to have it retuned but I will just wait and save my money for a vf22, pinks and fuel pump. Then have some real gains
K6DimE
Mar 31, 2006 01:35 PM
Antonio85
Jun 24, 2005 10:24 AM
epyon08
Aug 18, 2004 01:29 AM
Slack
Aug 25, 2003 09:45 PM
modwrx
May 10, 2003 05:44 PM
