will a MBC help the turbo spool faster?
Old Jan 14, 2006 | 10:37 AM
ride5000's Avatar
Originally Posted by projectwrx
i got different info from gruppe-s. they said it would be safe to run the basics without tuning. i would assume they know what they are talkin about???
it USED to be perfectly fine, on the bugeyes.
when stock cars are knocking, especially when run on 91 octane, why would you do anything to make it worse?
the situation does not manifest itself during dyno pulls, or when you floor it at 2k and take it to redline, because in those situations the delay times out before the boost comes up.
it occurs (and does damage) when you're sitting there at 4k rpms and low throttle angle, and then suddenly punch it. the boost hits quickly and will easily peak before the delay times out.
i run my car lean but i'm not going to run 14psi @ stoich fuel. you could/would be doing that on 91 octane which is even worse!
also, when gruppe-s says "the basics" does that also entail fitting an MBC? and if so, what is the MBC set to? an MBC set to 10psi will run stoich fuel all day long, whereas one set to 16psi will detonate and/or melt stuff at 14.7:1.
mike/mpjbecks at gruppe-s does know his stuff. are you giving him the full story though?
Old Jan 14, 2006 | 03:12 PM
slvrsubywgn's Avatar
Another option for quicker spool-up is to upgrade your boost solenoid and the lines. A few different companies offer them, such as Perrin and GM. I know you can pick up the GM product for around 75 dollars. And they are really simple to install.
Old Jan 14, 2006 | 03:42 PM
ride5000's Avatar
fwiw, most folks who have installed an interrupt style "3 port" solenoid (gm, perrin, grainger, etc) in place of the oem 2 port have required custom tuning to get the boost response stable. in fact, i only know of one who didn't.
Old Jan 17, 2006 | 09:15 PM
UK n00b's Avatar
Car Info: the blue bucket
i got different info from gruppe-s. they said it would be safe to run the basics without tuning. i would assume they know what they are talkin about??? good info, though...
lurk, why save for a ecutek? isnt the cobb ap better?
Basic bolt ons would be ok on say a 02/03 WRX or 04+ STI but with the issues covered above (CL vs OP switchover) the 04+ WRX, FXT, LGT would/could suffer from issues with the new found flow improvements of say a free flowing exhaust or the faster onset of boost with a MBC/EBC.
Whoever you spoke to at Gruppe-S either missunderstood the question or didn't realize the car you were driving.
Mike
Old Jan 19, 2006 | 01:43 PM
06WRX420's Avatar
Car Info: 2006 WRX Gray
If you love your car just forget about using a MBC. I got a COBB AP and love it!!! Along with increasing boost safely to 15.78psi, the peak torque and HP kick in about 800rpms sooner than stock, you cant get that from any MBC.
Old Jan 19, 2006 | 04:19 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
this thread is strikingly similar to this one...........
https://www.i-club.com/forums/engine-management-66/safe-run-up-dp-cbe-without-cobb-ap-122961/
with the exception of using an MBC.
-Ted
Old Jan 23, 2006 | 08:25 AM
projectwrx's Avatar
Car Info: wrx
Mike
thanks for clarifying.
i wasnt planning on using the mbc to raise boost, just for the quick spooling effect.
415er
May 3, 2008 12:49 PM
Markadopolus
Sep 10, 2006 02:15 PM
gruppe-s
30
Oct 19, 2005 02:59 PM
Gomy's_WRX
Sep 28, 2005 10:14 AM
kongzilla
Jan 1, 2003 07:57 PM
