Burning oil smell....help!
Im burning oil (not in the combustion chamber but oil is dripping onto the hot exhaust and/or engine block. Every time I stop or park in my garage it smells like burning oil. Im not sure were its coming from, the oil pan is pretty clean, i just did valve cover gaskets and spark plug O-rings, what else can it be? The oil looks is manly dripping off the cross member onto my swaybar then dripping onto the exhaust.
Is it a leaky separator plate? Is there anyway to make sure it is the separator plate before I drop the tranny and realize thats not the problem? If it is the separator plate is there anything else i should do while i have the tranny off?
~Leor
~Leor
Location: Automotive racist capitol of the world, Detroit.
Car Info: 2000 impreza 2.5 rs
I am not to sure where the oil pump is on these cars . I would guess that it is a crank shaft seal eather on the front or back side of the engine.
Originally Posted by WRC1
^^^Im starting to think its a rear crank seal too. I am not looking forward to that work.
~Leor
~Leor
good this you told me, i would probably do it that way to. Any uggestions on how to change it? Or even better a write up?
~Leor
~Leor
I dont know how the engine seals are held in this will work if they are a press fit but most likley wont if they are captive.
Tele-Viper
07-03-2008 07:44 AM
WREXNFX
09-07-2005 02:50 PM
