Max Boost & Fuel Cut questions
Old Nov 25, 2002 | 05:51 PM
Wheels's Avatar
MMM if I was a mod this would be in Forced induction!
Old Nov 25, 2002 | 06:17 PM
Wheels's Avatar
Originally posted by Hassassin
well ur not so shutup, but thanks for the useful info!!!!!!!!
In relation to the first question the turbo can put out 19PSI without problems. As for the fuel cut off it is probably arround 17psi.
What will happen is the ECU will shut down the fuel pump for a fraction of a second but you will feel it.
Old Nov 25, 2002 | 11:33 PM
nqwan's Avatar
Car Info: o2 duburu arr exu
if you just peak at 17psi you shouldnt be getting a fuel cut. you will however if you hold 17psi. my stock turbo has actually spiked to 1.5bar without a fuel cut (happened when i first put in my headers and mbc).
don't worry about the cel. assuming you lowered your boost to >17#, it'll clear after you drive for a couple days. try keeping boost at around 16# and see what happens. if it doesnt clear after a while, you may want to pull the code to see if anything else caused it besides the overboost condition.
silver ghost
Dec 26, 2004 07:11 PM
wrxraybrand
Aug 9, 2003 08:48 PM
pacobeagle
Jun 16, 2003 03:10 AM
Hassassin
Nov 26, 2002 01:04 PM
