Can Fuel Cut lead to leaking fuel or oil?
Old Dec 25, 2004 | 12:21 AM
silver ghost's Avatar
I just got my STi EcuTeked along with an APS 3" Turboback install and a 255 walbro fuel pump. In colder weather for the last couple of days when accelerating hard in 5th or 6th gear the car's boost gets interrupted and it feels like i'm momentarily hitting a wall...abrupt hesitation like i've hit the rev limiter except i still have a way to go before redline. Right after this happens the CEL light comes on along with the Cruise light blinking...it goes away after i shut the engine off for awhile and start it back up. I am thinking it is fuel cut and this situation can be resolved by pulling the timing but when i pulled into the garage tonite i noticed some black spots directly under where the engine bay is supposed to be...it looks like oil but smells like fuel...any guesses to what the cause of this leak is? Am i running lean? Leaky gasket? Can fuel cut cause a leak somewhere in the engine bay or is this just an improper install of the turboback or fuel pump?
thanks, Ghost
Old Dec 26, 2004 | 07:11 PM
Krinkov's Avatar
sounds like your hitting boost cut, but you have an Ecutek tune
what PSI are you hitting when it happens?
JourdanWithaU
Jul 23, 2015 09:22 AM
RU-X
Mar 12, 2007 12:45 PM
dunnojack
Nov 14, 2005 05:13 AM
wrxout
Oct 26, 2005 03:13 PM
pacobeagle
Jun 16, 2003 03:10 AM
