CFM chart
Old Nov 22, 2002 | 05:46 PM
hotrod's Avatar
credit for work
scottm1978:
Umm if your going to just cut and paste someone elses contribution to your NASOC thread,
http://forums.nasioc.com/forums/show...hreadid=278517
You should at least include credit for their effort.
Larry
Old Nov 22, 2002 | 06:05 PM
hotrod's Avatar
Higher PSI values
Phast:
I was just curious where the "max boost" figures came from. The 20G is well known in DSM land, which I'm sure you are familiar with. I know it's efficient well past 20psi. Maybe 23-24 easy.. and sometimes even 25psi.
You're absolutely correct that many of those turbo's will reach higher boost levels. When I put together that portion of my list, I tried to standardize on a pressure ratio of 2.5 for the high boost value. In some cases the source did not list values that went that high. In some cases the compressor map could support higher pressure ratios at moderate flow rates but fell on its face at higher flow rates.
In the case of the 20G
http://www.stealth316.com/images/td06h-20g-cfm.gif
it achieves max CFM flow at 20 psi, but is capable at slightly lower flow rates of 26 PSI.
Larry
Old Nov 22, 2002 | 11:39 PM
hotrod's Avatar
Just another little note
Thanks Scottm1978 -- no harm no foul.
Just a note to everyone I just decided to change my rating of the 16G large on the other page. In answering Phast I found some things didn't quite add up right.
I went back and after scratching my head for a while decided I must have miss-read my hard copy print out of the 16G large compressor map, when I put the first draft of the list together. I have decided to up grade its flow at 22 psi to about 520 CFM instead of my orginal 470.
It will heat the air discharge more than the 16G small due to its lower compressor effeciency, so the density of the air discharged will only be about 96% of the 16G small at the same pressure.
Like I posted on the other post this is a work in progress, and I'm sure I will change other values as I evolve a consistant way of evaluating the numbers.
Larry
Old Nov 25, 2002 | 01:47 PM
hotrod's Avatar
could you check your compressor map
AZScoobie:
Could you do me a favor and compare your compressor map to the one I referenced in the other thread that was posted by sherifx.
http://forums.nasioc.com/forums/show...ompressor+maps
As he has it dimensioned at the bottom the far right edge of the map ends at 17.5 Meters cubed/min or 618 CFM. I suspect when he penciled in the indexes at the bottom they were about 2 divisions off, or he actually has a map for an 1818.
That is why I didn't take my numbers on that thread all the way up to your recommendation of 695 --- it just doesn't exist on that map. The 600 value for 22 psi represents where the max rpm line and the flow lines end at about 16.8 Meters cubed/min at PR 2.5 or 593 cfm. So that map and your map just can't be the same.
Current values in the other thread:
Code:
Stock Turbo       360 CFM at 14.7 PSI
T3  60 trim       400 CFM at 14.7 PSI
IHI VF 23/24      423 CFM at 14.7 PSI
STOCK  HYBRID     430 CFM at 14.7 PSI
IHI VF-22         435 CFM at 14.7 PSI
SR 30	          435 CFM at 14.7 PSI
T04E 40 trim      460 CFM at 14.7 PSI
Small 16G         505 CFM at 14.7 PSI
Large 16G         550 CFM at 14.7 PSI
SR 40	          595 CFM at 14.7 PSI
18G               600 CFM at 14.7 PSI
PE 1820           630 CFM at 14.7 PSI
20G               650 CFM at 14.7 PSI
SR 50             710 CFM at 14.7 PSI
GT-30             725 CFM at 14.7 PSI
60-1              725 CFM at 14.7 PSI
GT-35R            820 CFM at 14.7 PSI
T72               920 CFM at 14.7 PSI  <-- Note you would have to spin a 2.0 L
                                           engine at about 14,000 rpm to flow this much air.
IHI VF 23/24      388 CFM at 18   PSI
T3 60 trim        410 CFM at 20   PSI
IHI VF-22         460 CFM at 18.0 PSI
AVO 320HP         465 CFM at 17.5 PSI
T04E 40 trim      465 CFM at 22   PSI
SR 30             490 CFM at 22   PSI
Small 16G         490 CFM at 22   PSI
Large 16G         520 CFM at 22   PSI  <--  upgraded flow some on review of compressor map
AVO 400HP         580 CFM at 17.5 PSI
PE 1820           600 CFM at 22   PSI
AVO 450HP         650 CFM at 20.0 PSI
SR 40             650 CFM at 22   PSI  <--- added, got lost some how in editing
20G               695 CFM at 20.0 PSI  <-- added
AVO 500HP         725 CFM at 23.0 PSI
SR 50             770 CFM at 22   PSI
GT-30             790 CFM at 22   PSI
60-1              800 CFM at 22   PSI
GT-35R            880 CFM at 22   PSI
T72              1000 CFM at 22   PSI  <-- note you would have to run a 2.0 L engine
                                           at >40 PSI boost to flow this much air
HKS GT2835 Turbo about 400 hp approx 580 CFM, pressure not specified
HKS GT3037 Turbo about 460 hp approx 670 CFM, pressure not specified
HKS GT3040 Turbo about 490 hp approx 710 CFM, pressure not specified
HKS GT3240 Turbo about 570 hp approx 830 CFM, pressure not specified
To maintain my sanity ( like you said multiple boards are confusing) I'll try to keep that thread corrected as I learn new info.
Scott1978 ---- since your first post is at the top of this thread why don't you just periodically import (Cut&paste) the master list on the other side to your post so the most current info sits at the top of this thread also? Just put a last updated line in it.
By the way scott1978 -- if you surround the number block with the flags for {code] {/code] (replace the front brace with a square bracket to make them work) you can preserve spaces.
Larry
Old Nov 27, 2002 | 10:16 AM
protocol_droid's Avatar
Oh yeah, where's the 18G in the high psi region, and would this be the greddy 518 upgrade? Confused.
Old Nov 27, 2002 | 12:27 PM
hotrod's Avatar
Haven't got a map for the 18G
I haven't been able to find a map for the 18G, so have no numbers above the basic. It should fall between the 16G and 20G, or just over 600 CFM, but would love to find someone who has a compressor map or knows where to find one. A lot of these turbos are right on the far right edge of the compressor maps at pressure ratios around 2.4 - 2.6 and do not flow significantly more max flow at higher pressures. If that is the case if the turbo will not supply enough air for the engine at pressure ratio 2:1 then you will gain nothing by upping the pressure.
If it is comfortably below what the engine needs at 2:1 then it will improve hp output to bump the pressure up some.
Larry
