tires rubing rear fender
Old Mar 4, 2004 | 02:36 AM
BongMan's Avatar
Car Info: '01 RS BRP
Thumbs up
Way to prevent rub are stiffer suspension, cutting/rolling fender and slightly more camber(not sure about this one).
I don't think a sway bar will do enough to prevent rub. Only the rear ever rubs for me, and i have plenty of rear stiffening stuff.
Before I had 225/45 17 at stock height. They rubbed. i cut one fender but they rubber on both sides. I ended up destorying 2 tires. So i learned my lesson... for now.
Most likely you will need to revise your setup for more travel and get stiffer springs and struts.
I hope this helps.
FXTbrah
Jun 7, 2011 09:21 PM
RallyTard
Dec 21, 2009 08:36 AM
Yesitsdrew5310
Dec 3, 2006 10:03 AM
70sixspeed
Oct 31, 2005 03:57 AM
MO REX
Apr 24, 2005 08:41 PM
