Suspension Clunk ? Need Help
Old May 25, 2007 | 04:05 PM
tom_walshaw's Avatar
Car Info: 2002 WRX
I put 04 sti suspension onto my 02 WRX, worked fine for aorund 6 months but now im getting a clunking sound everytime the right rear hits pot holes, bums, anything really! Any ideas what could be causing this ? Thanks
Old May 25, 2007 | 05:29 PM
abakja1's Avatar
Car Info: 08 Nissan Titan, 12 MazdaSpeed 3, 15 Honda CRV
Let me know what you find out,..I have a rear pass clunk too I want to figure out.. Some say its the endlinks, tophat for the rear shock, or even the swaybar moving in the swaybar bushings.
Good luck
Old May 28, 2007 | 08:31 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Have you checked to make sure all the bolts are tight? It could be a couple things so a visual check will be a good starting point.
Old May 30, 2007 | 11:45 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Rear sti struts are known for clunking. Only thing to do is replace.
Old May 31, 2007 | 10:47 AM
lin_tp2's Avatar
Car Info: 02 wrx
i have the same issue on my car as well. I installed my 04sti struts on my 02 wrx maybe 2 years ago and the clunk never go away. I have tried to tighten the tophat bolt once and the noise went away for a bit but now its back. There is a 500 page thread on nasioc if you want to read more. It doesnt really hinder performance so im just going to keep mine for now until i have money. hope this helps
linford
Old May 31, 2007 | 12:25 PM
Car Info: 2002 WRX
Thanks guys, ive checked most of the bolts, they all seem fine, yeah im hearing more and more that its just summat that happens!!! Oh well, yeah guess il start looking for new suspension then, its so annoying!!!
Old May 31, 2007 | 02:54 PM
MO REX's Avatar
Are you guys running 02 rear tops with 04 STI struts? They changed the design of the rears in 04.
Old May 31, 2007 | 09:51 PM
Car Info: 2002 WRX
No, i made sure i got some 04 tops! I thought that also, but checked and they're definatly for 04's .
05SPECV04STI
Jan 8, 2007 03:06 PM
impreza25rstn
Mar 18, 2006 01:59 PM
ryeoj2003
May 16, 2005 08:21 AM
DWNSHFT
May 9, 2004 11:52 AM
gordy
Dec 2, 2003 01:07 AM
