Is A Rear Brake Kit Worth It?
Old Nov 29, 2002 | 02:07 PM
GarySheehan's Avatar
Car Info: 2005 Subaru STI
We use the Stoptech front kit and just run a hot pad in the stock rear calipers on the stock sized rotors. Our rear temperatures never get very high and our pads wear nicely. I don't see a reason to upgrade the rears with a front setup that's properly balanced for the system.
Gary
Sheehan Motor Racing
www.teamSMR.com
Old Nov 30, 2002 | 07:26 AM
mav1c's Avatar
Car Info: STI Track Car, Titan Tow Vehicle, Mazda3 DD
I also run the Stoptech front kit, but I did upgrade the rears to the larger Legacy rotors (11.4" vs the stock 10.3"). I run Axxis Ultimates in the rear ccalipers, and this overall set-up is gret. The rear pads wear MUCH slower than the front at tracks days, and there's never been any overheating problems.
Old Nov 30, 2002 | 09:13 PM
ImprezaRSDriver's Avatar
I have the StopTech kit up front on my WRX right now and I have vented rear rotors. The rear rotors that I have are the same diameter as the stock solid rotor with the exception that the setup is from an older generation Legacy. It uses a different caliper and bracket but it bolts right up to a stock Impreza dust sheild without modification.
pwn
Jan 31, 2008 10:35 AM
kansai_wrx
Jun 27, 2006 12:28 AM
New2MeSuby
17
Jan 22, 2004 09:09 PM
davenow
16
Nov 27, 2002 07:02 AM
