Is A Rear Brake Kit Worth It?
Old Nov 22, 2002 | 09:20 PM
ImprezaRSDriver's Avatar
I have the rear two pots on my RS right now and boy does it work really well. Like the brake balance could not be better. But to get it installed is the pain. You need to have the hubs pressed out. But right now the car feels stable under hard braking and I have no fade at all.
Old Nov 24, 2002 | 12:07 AM
I belive that Wilwood also has a 4pot rear setup for the WRX as well. That is 20 pistons for stopping.
Old Nov 25, 2002 | 07:44 PM
I am estimating from around 3-4k for the whole setup from and rear with the 6 piston fronts and 4 piston rears.
Old Nov 28, 2002 | 02:43 PM
PGM's Avatar
PGM
Car Info: 2K2 PSM WRX WGN
According to this article on Stoptech's site, they think rear
break upgrade isn't really necessary if you use their system.
http://www.stoptech.com/whitepapers/...tter120601.htm
