Not a fan of coilovers
Old Jul 4, 2003 | 09:59 AM
  #32
DarriiffftaaHuy's Avatar
I have KYB AGX's with Ground Control and 250/200 lb Eibach Springs w/ a 2"+ lift. First of all, the GC Perches get stuck and are impossible to adjust. For some reason, the ride in back is bumpy and jerky and noisy no matter where I set it at, but the front is PERFECT! The front is smooth and quiet, yet soaks up bumps like no other. The only difference I see is the spring rate and the top mount... can they be the reason why it sucks?
Old Jul 25, 2003 | 08:28 PM
  #36
Indi's Avatar
Tad -
How much for the Tein Wagon Coilovers? Where? And how much for the labor?
srh
Old Jul 26, 2003 | 12:19 AM
  #37
MPJ Performance can get you Tein Type Wagons for about $1000-1100 installed. They are located in Hayward. www.mpjperformance.com ask for Mike.
Old Jul 26, 2003 | 01:08 PM
  #38
Z1 Performance's Avatar
I'd have to disagree with Alex on several fronts on this (yeah, I know he answered a long time ago!)
You can achieve the desired rideheight easily by picking the right springs, so coilovers are not necessary at all. My main reason for not always steering a customer towards them is the compromise in ride quality you often get, as well as the associated noises. They are certainly not for everyone.
As for cornerweighting, you cannot cornerweight the setup unless it is dual height adjustable (adjustable lower bracket as well as spring perch). Otherwise, you are going to be altering rideheight from one wheel to the other.
Springs and shocks are not inferior at all IMHO....in many cases, they are superior, due to thicker pistons and better overall valving. Now, if we are talking the Tein RA, Cusco Zero 2, JIC FLTA2 range, then I agree, the coilover is superior to any spring and strut in terms of handling and adjustability, but a good spring and strut rivals the less expensive options out there IMHO.
As for the Wagon, yes the strut length differs slightly from sedan to wagon, but it really is not too great a concern when fitting coilovers, as the rideheight will always be dropped by around 1/2 inch regardless merely by installing a coilover. We have done the wagons on a sedan countless times, and it works like a very well set of matched springs and struts, that also happens to be height adjustable. The wagon really does not need a significantly (if at all) different spring rate than the sedan, as the weight difference is minimal.
Adam
Old Jul 27, 2003 | 02:47 PM
  #39
davenow's Avatar
Originally posted by teiva-boy
Alex, the problem though with coilovers is cost. Although it's cool to set it and forget it and it should be thought of that way... Is it really worth it to pay a few hundred dollars or more for something you may never need?
Although a different person would say that it's better to have and not need then to need and not have
You pay a few hundered more for HANDLING.
There is NO comparison to how a car on a decent set of coilovers handles compared to a shock/strut/sping type.
you can stick with your struts, but the coils WILL outhandle them by a mile
mattsn0w
Mar 15, 2009 07:05 PM
ryball
Jul 31, 2004 01:46 PM
IS2Scooby
Sep 5, 2003 05:25 PM
IS2Scooby
Aug 14, 2003 02:06 PM
