HELP: Cutting Coilovers
Old May 25, 2010 | 12:41 PM
MonsterGC's Avatar
Car Info: 2000 2.5rs
hmm you going to have to mess with the preload for that (the lower spring perch)
Old May 25, 2010 | 12:58 PM
Su_Buru's Avatar
Car Info: Searching...
well the preload just lossesns and tighents the springs. the springs cant be too loose can cause it will just be wobbly
Old May 25, 2010 | 11:08 PM
MonsterGC's Avatar
well you just lose suspension travel when the car sits on it the spring gets compressed again and will not be wobbly
Old May 26, 2010 | 11:56 AM
Su_Buru's Avatar
so would you recommend releasing the preload before you drop the car?
Old May 26, 2010 | 11:58 AM
silverbullet415's Avatar
i wouldnt cut the springs
Old May 26, 2010 | 12:05 PM
Su_Buru's Avatar
i have already established that i am not going too
Old May 28, 2010 | 01:08 AM
MonsterGC's Avatar
As long as you are not going rallying and not releasing the preload too much it will be fine, Just lower the car slowly and it will sit back in the right spot
Old May 28, 2010 | 09:04 AM
Su_Buru's Avatar
yeah ive lowered it while it being kinda loose and i still have to watch out for my boot.....i think ima just have to go to that one website and but some springs for the front....if i have different springs in the front, do i have to have the same set of springs in the back or can i run the stock megans in the back and the new one in the front without any problem?
Old May 31, 2010 | 12:16 AM
AlanNgo7's Avatar
Car Info: STi 2008
Lol the video!!!
Old Jun 4, 2010 | 09:56 AM
Su_Buru's Avatar
did some experiencing and i finally found out how to lower my ride without any problem
Su_Buru
Dec 31, 2010 10:13 PM
danninchrissy
Nov 2, 2005 06:45 AM
Vicore_Wrx
Sep 22, 2004 10:34 AM
Wrxplaya11
Feb 27, 2004 08:39 AM
SF miami WRX
Jun 9, 2003 04:32 PM
