Brake noise
Old Feb 15, 2010 | 05:25 PM
b_mendiola's Avatar
Car Info: 2004 WRX
Brake noise
i have an 04 wrx wagon and the front brakes rattle a bit more than i think they should. i know they are floating calipers but i can kick my tire and here a metal clunk from the calipers. if i hold the caliper and kick the tire the noise is gone so i know its the brakes. any info on how to eliminate so much play or how to dampen the noise.
Old Feb 16, 2010 | 11:17 AM
b_mendiola's Avatar
Car Info: 2004 WRX
Unhappy
anyone have the same noise or is it just my wrx
Old Jun 10, 2010 | 04:01 PM
nolan's Avatar
Car Info: 02 MBP wagon
You should definitely not be hearing a clunk from kicking your tire.
Get it checked out if you don't want to pull your brakes apart.
I would call this a legitimate safety issue.
Old Jun 12, 2010 | 07:24 PM
Wutzdatbehindu's Avatar
Car Info: 2002 Subaru WRX
is there any freeplay? I mean when you have the car up on a jack...crouch facing the wheel so you are looking straight at the rim...try grabbing the wheel on the top and moving it back and forth...i had the same problem and it turned out to be a wheel hub issue.
ThisizBrian
Jun 11, 2006 08:48 PM
skyewrx
Aug 1, 2004 12:30 PM
silver fox
Feb 16, 2004 07:17 PM
silverfox1
Feb 15, 2004 02:21 AM
Lowball
Mar 6, 2003 07:00 PM
