Redline Oil (recommendations for engine and drivetrain?)
Old Aug 7, 2008 | 09:33 PM
pacer07's Avatar
Car Info: Subaru WRX TR 07
Im thinking of switching all fluids in my car to Redline. I currently run Royal Purple in the engine and always have but i just hit 20,XXX and want to swap out the rear diff and transaxle fluids. Heres my questions:
I plan to use the Redline 80w90 gl5 w/friction mods in rear. Am i correct to run the 80w90 gl5 wo/friction mods in transaxle?
Should i switch from Royal to Redline in the engine?
Thankyou in advance and my car is a 07' TR with 5-spd.
Old Aug 8, 2008 | 10:26 AM
subie OCD's Avatar
Car Info: 04 STi
I wouldnt put Redline in the transmission - I did a lot of research when I had my old wrx and there were lots of cases where 1st gear would grind after putting in synthetic tranny fluid. I would recommend non synthetic for the transmission.
The rear diff, however, is ok with Redline. I used Redline 75-90 gear oil in my old wrx and plan to use it in my STi.
As far as motor oil - as long as you use the proper viscosity (for your areas temperature and your driving habits), you cant really go wrong. Just make sure to use an OEM oil filter.
Old Aug 8, 2008 | 10:32 AM
VRT MBasile's Avatar
Swepco in the tranny and diff....its amazing
Research if someone near you carries it, otherwise you might have to order it, but it is definitely worth it.
Old Aug 8, 2008 | 10:58 AM
reline in my motor for 145k miles
tranny i use dino or torco it works for my car
Old Aug 10, 2008 | 02:11 PM
Lurk's Avatar
Engine oil makes no real difference, especially if you change every 3k. I've used Castrol (Euro formula),Torco, Mobil 1, Redline, Motul, Neo, RP, etc.
They're all the same.
Old Aug 10, 2008 | 02:49 PM
702STI's Avatar
Car Info: 3" bellmounth dp, hks exhausts&fmic, cobb ap v2
i used redline when i changed my trans and rear diff....
Old Aug 12, 2008 | 09:23 PM
pacer07's Avatar
I know that its a difference you dont feel and that they all can work differently depending on your engine or driving style as far as protection level is concerned.
latebrake
Aug 29, 2009 08:21 PM
Imprezer200
Jul 18, 2006 09:34 PM
mmboost
Jan 9, 2004 11:25 PM
liberty2000rs
Oct 21, 2003 03:41 PM
SXPi
Dec 3, 2002 12:36 PM
