Loss of power randomly, Check Engine light on
Old Jan 11, 2005 | 12:57 PM
mike26's Avatar
Sounds like you should take it in and get it checked out at your nearest dealer.
Old Jan 11, 2005 | 02:37 PM
nachomc's Avatar
Sounds like something to do with the ignition components. I had something similar happen on my Acura and it was the igniter. I'd get it checked out soon. From the first time it did it to the last time it did it, which was when my car shut off while on the freeway and wouldn't restart, was about 100 miles.
Old Jan 11, 2005 | 02:38 PM
BlingBlingBlue's Avatar
From what I understand, it is ok to drive with the CEL on as long as it is not blinking. You should probably take it to somebody who can pull the code to see what error ocurred.
Old Jan 11, 2005 | 11:13 PM
imporacer's Avatar
Sounds like a cylinder misfire.
Old Jan 13, 2005 | 12:30 AM
If it happened twice within a mile, I would be hesitant to drive it again. How old are the spark plugs? How many miles on the car? Have you changed plugs or wires ever? Fuel filter? Air filter? If all the maintenance items are good, it's probably going to be a failed sensor- MAP, O2, TPS, etc.
Old Jan 13, 2005 | 08:57 AM
DreddRS25's Avatar
Car Info: BRP Impreza RS MY01
Did this get resolved?
I own a MY01 RS also. When I bought the car (used) the carfax reported that there was a recall on the ECM for my car and it was replaced when sold back to the dealer.
I bought it with 63k and it now has 87k and still running strong.
I would also check the ignition system. If you have a CEL pull that code.
TDubRX
Aug 8, 2006 11:36 AM
wombatsauce
Mar 26, 2005 02:24 AM
Diverdave
Jan 4, 2005 04:39 PM
WRX_NICK
Apr 27, 2004 08:36 AM
mmboost
Jan 9, 2004 11:25 PM
