AT OIL TEMP light & CEL + extreme power loss on freeway
Old Dec 30, 2004 | 09:31 AM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
It sounds like the tranny fluid is simply getting extremely hot and eventually causing the CEL. I guess at that point, the ECU probably retards performance so you don't destroy something. Perhaps an AT temperature gauge would help. Maybe there's some problem with the tranny cooler as well...
Old Dec 30, 2004 | 09:14 PM
THAWA's Avatar
FWIW you shouldn't turn the car off when the AT OIL TEMP light comes on. You should just let it idle, that will cool it down faster than shutting it off.
Old Dec 31, 2004 | 09:07 AM
DLC's Avatar
DLC
THAWA's right, it needs to be running in order to circulate the coolant though the radiator.
Island Style
May 26, 2006 08:59 AM
bigsexyy81
Jan 13, 2005 08:57 AM
gordy
Oct 27, 2004 03:03 PM
mmboost
Jan 9, 2004 11:25 PM
Blue-Adept
27
Nov 15, 2003 11:19 PM
