STI Power Loss after first Oil Change?
Old Sep 16, 2003 | 05:35 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
As the motor breaks in, the rings seal better, providing higher combustion chamber pressures. With that, the power goes up.
If the power goes down, I bet the motor has not been broken in properly.
What kind of oil did he put in at 3000?
Old Sep 16, 2003 | 05:48 PM
Imprezer's Avatar
Admin v2.0
There is the problem, I think.
3000 miles is too early to switch to Synth if you ask me.
Old Sep 16, 2003 | 06:28 PM
Imprezer's Avatar
Admin v2.0
The thing about Synth oil, is that it is too slick. Thats good. However, when the engine is breaking in, you don't want everything to slide easy. You want it to run and wear in. Rings especisally.
So, if the oil is too "oily", the break in procedue could just stop or take longer to complete.
I recommend running regular oil for 5000 miles, then switch to blend and then to fully synth.
Old Sep 17, 2003 | 11:30 AM
2fcknfst's Avatar
Car Info: 2002 3/4 ton Cevy Suburban, 1997 Integra Type-R, 2004 WRX-STI
I just changed my oil yesterday. subaru Canada has suggested not going to a synthetic until 12-16000km due to the components in dino oil that help seat everything in the motor. Sort of like a extended treating process for the metal.
By going syn, it is possible the the oil will not correctly bond to the metal. I'm not a metalurgist, but this is consistant with other things I have seen in my line of work.
