HELP! Clunking sound!
Old Jul 13, 2012 | 02:14 PM
TheLegend's Avatar
Enjoys his Ponies
Car Info: 2014 Mustang GT Premium 5.0
Have you checked to make sure that there isn't a small child in your trunk?
Old Jul 13, 2012 | 08:02 PM
JFlipSubi916's Avatar
Car Info: 07 WRB WRX
Nope...no small children lol.
Hey, so I checked it again, and it sounds like it's coming from the front of the car.
Again, it's usually when I'm engine braking and it only occurs under 2.5k rpms. But when I clutch in, hit the brakes (only sometimes), or press the gas again, it disappears. Some people on other forums say it may be a heat shield, but if that were the case, wouldn't it be rattling more often instead of at certain rpm ranges?
Old Jul 13, 2012 | 08:52 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
heat shields don't clunk. you could come by and i'll take a listen if you'd like.
Old Jul 13, 2012 | 09:14 PM
strider327's Avatar
Car Info: 2005 WRX
It could be heatshields due to just enough vibration. When the car is dead cold, do slap raise the car and slap the heatshields and see if you can replicate the sound. My turbo heatshield was loose once and would only rattle during moderate acceleration.
Old Jul 13, 2012 | 09:20 PM
well it's not really clunking. it's more rattling now that i think about it. its like if you take some aluminum sheet metal and hit it with some zip ties, you might get that same sound.
Old Jul 13, 2012 | 10:29 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
the only rattling heat shield issue I had was on the up pipe, the welds on those break all the time.
Old Jul 13, 2012 | 11:10 PM
i really need to get my car up in the air and take a closer look. funny, i work at elk grove toyota and can use the lifts on my days off, but problem is, i really don't even know what to look or where to look for that matter. i would say my knowledge of cars is more or less book smart...not really practice smart...kinda lame haha T.T
Old Aug 6, 2012 | 11:22 PM
So...since I am pretty close to my 105k check up, I have a feeling that this rattling sound is my timing belt tensioner going out. I took a stethoscope to the engine and it originally sounded like it was coming from the valve train closer to the driver's side. However, I don't think I drive my car nearly hard enough for the valves to be going out nor do I keep my car malnourished of oil (in otherwords, there's always oil in the car lol).
The only thing I can think of now is that it's my timing belt tensioner. I haven't pulled the cover off as I don't have enough time to do it, but this seems to be the most common problem that I've found during my search for answers...
Old Aug 9, 2012 | 02:35 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
tensioners usually aren't issues. most timing belts done at 105k still look practically brand new. there's a few of us on here that can take a second look/listen.
Old Aug 9, 2012 | 09:52 PM
dthack03's Avatar
Car Info: bugeye
I would check the clearance around your downpipe near the transmission and around the frame. But if you don't have rear lockdown bolts, or fresh bushings, I wouldn't rule that stuff out, and either way they would be helpful.
Old Aug 10, 2012 | 09:17 PM
Well I am somewhat due for a timing belt service so I ordered the parts for that. Friend and I are going to take a look at ALL of it when we do the timing belt.
Here's a video of what it sounds like.
It happens around 0:33, 0:52, and 1:19. I'm pretty sure you can hear it throughout the video, but it's most audible during those times
Old Aug 18, 2012 | 01:04 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
sounds like your up pipe heat shield may be loose. if you swing by here i'll check it out for free, or grab me some food and i'll meet you wherever.
Old Aug 18, 2012 | 01:34 PM
qingshan's Avatar
Car Info: '06 CGM Fo/12 SWP Sti
I had a few sounds that were driving me crazy with my 05 sti. Feal Suspension redid my back struts and I did a better mount on the Perrin heatshield - sounds gone
Old Aug 24, 2012 | 08:30 PM
Sounds good. But I only have Tuesdays off from work. If I did meet up with you, where would u want to meet up at?
darkonion
31
Dec 9, 2006 07:44 PM
The_STI_Guy
Nov 13, 2006 10:01 AM
wvinfernovw
Mar 18, 2006 11:39 AM
ChuiSti
Oct 9, 2004 10:33 AM
drewster2002
Feb 22, 2004 05:06 PM
