Help! Clunking sound after installing cusco sway bars
Old Sep 30, 2004 | 06:36 PM
ChuiSti's Avatar
Car Info: 2005 CGM STi
I have installed cusco front and rear sway bars last week and now i have a clunking sound from the front of the car when i drive at low speeds, parking lot speeds when i go over bumps or turn (both left and right). I went under the car and retorqued every bolt involved during the installation (endlinks, swaybar mounts, AND the subframe) the clunking went away for one day, then suddenly came back again...any ideas on what it could be?
Old Oct 1, 2004 | 06:18 AM
04blkWRX's Avatar
Car Info: Black WRX, stock
My bars clunk except when I freshly lube the bushings.
Are you using stock endlinks?
Old Oct 1, 2004 | 11:40 AM
ChuiSti's Avatar
yeah i am using the stock endlinks, i lubed the bushings with white lithium grease the same day i retorqued everything, so i'm not sure if that's the same case for me
Old Oct 3, 2004 | 06:05 AM
04blkWRX's Avatar
Some folks suggest wrapping the bar with teflon tape. I tried that too but it was only a temporary fix.
Check around the subframe etc to make sure the bar is not able to hit anything when you hit a big bump.
Old Oct 7, 2004 | 08:32 PM
se0ul's Avatar
Car Info: 04 wrx, 05 Elise, 14 Impreza, 17 brz coming soon
mine was clunking in the rear due to the bolt coming out of the endlink/swaybar attachment. On one side my swaybar wasn't attached to anything and the endlink was just hanging there.
Old Oct 8, 2004 | 06:07 AM
04blkWRX's Avatar
I don't think Lithium grease has very good film strength. I tried the teflon tape, it seems to last longer than anything else (about a month...ha!).
Old Oct 9, 2004 | 01:08 AM
No other installs to the suspension? ALKs, strut tops, and spring/strut swaps are notorious for inducing clunks. If you haven't done that, try adjusting the setting on your sways to see if that helps. If it does, your endlinks could be contacting the sway bar where the spade end is flattened and the bar gets round again.
Old Oct 9, 2004 | 10:33 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Your might be binding in the front and cluncking.
Loosen it up and then re-tighten it.
i<3dirt
Oct 20, 2014 10:26 AM
rubberbulletz
Jul 31, 2011 10:49 PM
TylerSTI
Nov 20, 2007 10:51 AM
hayakunai
Oct 10, 2006 03:12 PM
wvinfernovw
Mar 18, 2006 11:39 AM
