After engine swap, transmission will not go into gear (was: Weird Situation)
Old Nov 5, 2006 | 12:52 PM
jmr79's Avatar
Car Info: 1999 Subaru Leagacy Sedan 30th anniversary
I have just swapped my old engine out for a newer used and it is running swell. The only problem is that I took it for a test drive. I reversed out of the drive way. Started down the street but for some reason it switch over into 2nd gear. then it shut down. I stopped turned it back over but it will not go back into gear at all. Any Ideas wht might be wrong??
Old Dec 1, 2006 | 11:48 AM
Jonathan's Avatar
Car Info: 1999 Subaru Legacy GT Limited - Quick Silver Metallic
Tell us more ?
What year legacy ?
What engine were you using, and what year did you replace it with ?
Did you keep the same air intake setup ?
Also what transmission are you using ?
i<3dirt
Oct 20, 2014 10:26 AM
djstatistics
Apr 10, 2010 09:21 AM
MindzeyeWRX02
Jan 6, 2010 01:35 AM
SoBaLo
May 5, 2004 03:26 PM
