Ticking
Old Apr 4, 2004 | 08:13 PM
Deride's Avatar
Car Info: 2002 Subaru Impreza 2.5 RS
Ticking
Anyone know what causes that aweful ticking in subarus? is it a belt issue or valves or what? I have an 02 2.5rs and my dad has a 01 Outback they both do the same thing, as well as most of the other subarus we test drove before purchasing. Seems to do it more when you first start it.
Old Apr 5, 2004 | 02:18 PM
Dirk's Avatar
Car Info: Silver 99 2.5rs coupe - stock(for now =) )
mine does it ALOT when i turn the car off, I sounds like it is coming from under the car. I wish I could help sorry.
Old Apr 6, 2004 | 02:43 PM
WRXFool's Avatar
My 98 RS does this as well. My first fear was a sticking lifter, but the ticking doesn't seem to follow the engine rev.
Any knowledgable (sp?) engine gurus out there have any ideas?
Old Apr 6, 2004 | 06:58 PM
mule2k's Avatar
I've just always heard that Subarus have "valvetrain clatter". It doesn't seem to be an issue.
Old Apr 7, 2004 | 10:09 AM
bheinz57's Avatar
Car Info: '02 OBS '03 Baja
Most likely the injectors. They tick quite loudly. Mine always ticks kinda like a small exhaust leak. Brian
Old Apr 13, 2004 | 05:20 PM
JohnQGearhead's Avatar
Car Info: '00 RS, Subrosa Letum
The ticking after the car is started could be piston slap, if it was cold. That means it should somewhat go away after it has warmed up.
The ticking after the car has been shut off is the exhaust pipe. Heat expands the metal so as it cools down the pipe is actually contracting, making it tick.
Old Apr 13, 2004 | 05:45 PM
Deride's Avatar
It almost seems like its a timing belt issue or something, its always the same pattern even if you give it gas.
turbo_j
Jun 13, 2003 11:26 PM
subysteve
Apr 3, 2003 06:09 PM
hilife
Mar 16, 2003 08:34 AM
scobaru
Mar 2, 2003 06:26 PM
AFIwrx
Feb 26, 2003 11:18 PM
