My car keeps overheating!
Old Oct 8, 2003 | 11:55 PM
Daredevil's Avatar
hmm
thats hecka weird.
hve you changed radiator fluid lately? caps on secure? im no car guru so i cna't help otu really
Old Oct 9, 2003 | 07:20 PM
Re: My car keeps overheating!
Originally posted by adj789
It tends to heat up when I'm stopped and cool off when I'm moving but then it...
Sounds like your fan stopped working. Troubleshoot the fan circuit before you replace the radiator. There's a good chance you only overflowed the reservoir instead of actually breaking anything.
Old Oct 10, 2003 | 01:18 AM
The thermostat doesn't directly run the fan in an OBDII car. The water temp sensor is responsible for that. The ECU turns on the fan when the temp gets to a certain point. (Or the AC is on)
Old Oct 10, 2003 | 01:36 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
It could also be a headgasget. A simple compression test will show you if it is the case.
Old Oct 10, 2003 | 05:10 AM
ImprezaVA's Avatar
Car Info: 1998 Subaru Impreza L 2.2
overheating
This is the first thing that crossed my mind. What year is your car? Also, what year did Subaru start making the 4 layer head gasket?
-Charles-
Old Nov 16, 2003 | 03:29 PM
sd70feb's Avatar
Car Info: 98 impreza 2.5 rs
i agree babu
JuanitoBurrito
Aug 23, 2011 08:49 PM
gsxbusar1300
Jul 18, 2008 04:49 PM
stg2lgcy00
Oct 1, 2004 02:09 PM
Vicore_Wrx
Sep 22, 2004 10:34 AM
