STi injector failure?
Old Mar 22, 2005 | 05:39 PM
xitonedefix's Avatar
Car Info: 1993 Impreza L EJ20 Turbo FWD
Has anyone else had injector failure? Like getting stuck open and hydrolocking the engine before it will even start. I bought a pair of brand new sti injectors. Im running them on an EJ18 ECU on an EJ22 Block, + Turbo.
Its possible that they were modified, like the perrin, or that it has something to do with the ecu im running. Im just asking if anyone had this problem
Old Mar 22, 2005 | 05:42 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Of course ECU.
Old Mar 22, 2005 | 06:02 PM
it was stuck open like halfway i guess when i first installed them, and then it started working properly after a few days, but then it just stuck completely open now. after about 3
3 months
Old Mar 22, 2005 | 06:10 PM
Imprezer's Avatar
Admin v2.0
I doubt your EJ18 ECU is capable of driving STi injectors. Why did you only get two? You need to get a WRX ECU and get it reflashed to compenstate for the larger displacement engine and other other custom parts.
Old Mar 22, 2005 | 06:45 PM
UK n00b's Avatar
Car Info: the blue bucket
Are you using the USDM side feeds? if so you can pop off the cap on the top of them and check the piston part (not sure what's called) as I have seen them stuck and been able to pull them out and to start working again (I only saw this on a modified set though not a new set.
Mike
Old Mar 22, 2005 | 06:49 PM
I drove the car for 3 months with the USDM STi 550cc injectors on stock ecu, but i am useing an Apex'i S-AFC also.
Would a WRX ecu plug into my stock wiring harness though?
sponaugle
16
Jun 18, 2004 03:25 PM
Jon P. Jacobs
Nov 8, 2003 05:33 PM
Ayapon
Jul 29, 2003 02:37 PM
Mr. Rogers
Jan 4, 2003 09:28 AM
